I have created a simple drawing of a part I was modeling this weekend at
home, and came across this interesting problem I never encountered before.
Basic, all it is a cylinder part of a bulkhead mounted switch, and an array
of solder lugs. I created the first lug as shown, and then was going to make
a pattern of it. I selected the AMDT_RECTPATTERN command, selected the edge
of the lug I had created. it highlighted as expected. I chose to make the
array on 2 columns spaced about .0785 apart. as it is showing the preview,
it shows a duplicate of the lug being patterned. when you select OK all you
receive is the basic block without the fillet or hole cut through. When I
did it at home I did it with MDT6, Here at work I did it with MDT5. Both had
the same results. I would have expected that if the preview showed the
correct result, that the final should also have the correct result. I am
posting this to CF, and the text only to both MDT5 and MDT6 groups.
Is this a bug? it supposed to be like this? Am I just too stupid to do this
correctly? I mean, if I had to array this feature 100 times would I have to
create the hole and fillet on each and every one of the arrayed pieces?
TIA
brian
