Lars,
There still is the old advice from MDT5 that might help:
- deselect "force hardware cursor" in the windows driver settings
- check if the pickbox isn't set to zero and the color of the cursor is OK
Sorry if this sounds too simple...
Leo Laimer
Maschinen- und Fertigungstechnik
A-4820 Bad Ischl - Austria
"Lars Sandberg" schrieb im Newsbeitrag
news:MPG.1714cccab9073779896b5@discussion.autodesk.com...
> Hi, by one of our customers, I have a problem with one of the
> installations: The cursor in the graphich area is missing in MDT R6.
> For trying to solve the problem, our customer performed the procedure
> below from Mike Dickason, without luck.
> PC spec's:
> MDT R6 SP3
> Inventor R5.3 SP1
> Windows 2000 SP2
> nVidia GeForce graphics (can't remember chip-version)
> nVidia Detonator 23.11 drivers
> 1024 Mb RAM.
> Another PC with same spec's performs well
> -snip-
> Subject: Re: Dissapearing cursor
> From: "Mike Dickason \(Autodesk\)"
> Newsgroups: autodesk.mcad.mdt5.support
> Trevor,
> Try the following:
> - Minimize all applications
> - Right click on your Windows desktop and select Properties
> - Select the Settings tab
> - Select Advanced
> - Select the Troubleshooting tab
> - Change the Hardward acceleration from full to one position down from
> full.
> - Select Apply and then OK out of all dialogs
> Now bring up MDT and see if you still have cursor problems.
> Mike Dickason
> Developer
> Autodesk Mechanical Group
> -snip-
> If anyone have some advise, I will look forward to that.
> Best Regards/ Med venlig hilsen
> Lars Sandberg
> TechSolution powered by IMAGINiT Technologies
> Mechanical Solution Center
