Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Mechanical Desktop 2009
3 REPLIES 3
DasBeast
1316 Views, 3 Replies
How canI tell if my copy of MDT 2009 is 32- or 64-bit?  Or was it even an option?
System Configuration:
Inventor Pro 2011, 64-bit edition
Build: 239
Windows 7 Pro, 64-bit
Intel Core i7 CPU @ 2.80 Ghz
12.0 GB RAM
ATI FirePro V8700, 1GB GDDR5
3 REPLIES 3
ceaky_s
in reply to: DasBeast
Anybody knows how to run AutoLIPS routines in Autocad Mechanical?
Tags (1)
Sridhar-Autodesk
Your copy of MDT 2009 is x64 because the system configuration shows the OS as Windows 7 Pro, 64-bit.  At the time of installation, the installer automatically checks for the OS type (x32 or x64) and  installs accordingly.  We cannot install x32 MDT 2009 on a x64 OS and vice versa.
Sridhar Subramani
Senior Product Owner
Sridhar-Autodesk
in reply to: ceaky_s
Open AutoCAD Mechanical>>Command Vlide>>open the lsp file>>Load the file>.Run the function.
For more info and help on AutoLisp, you may post further question on the following link.
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Sridhar Subramani
