IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Mechanical Desktop 2009 - Text disappears when MOVE command is used
4 REPLIES 4
Pattonskc
749 Views, 4 Replies
We have recently up graded from MDT 2007 to 2009. Now when I open drawings created in the old format and attempt to move simple 2D text (or dim figures) they completely disappear.
They CAN be moved using the editing handles.
But if I select an entire view (non-parametric geometry on the LAYOUT tab), selecting text dims and all with a window (or single pick items with the pick box), and use the MOVE command, all entities move as expected except the text entities which simply disappear.
4 REPLIES 4
Can you attach a sample drawing file which has the issue or send it to sridharDOTsubramaniATautodeskDOTcom
Sridhar
Sridhar Subramani
Senior Product Owner
Pattonskc
in reply to: Pattonskc
Thanks, Sridhar.
We have since discovered that after being moved the text can be seen by doing a REGEN, but that is time-consuming, too.
Scott
Hi Scott,
I could not reproduce the issue on MDT 2009 SP3. Can you insall SP3 from the following link and verify the issue again if its not installed?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019#section25
Sridhar
Sridhar Subramani
in reply to: Sridhar-Autodesk
Was this ever resolved?  Did updating to SP3 fix this issue?  I am having the same problem right now with the text disappearing after moving it to a new location.
Any help or insight would be greatly appreciated.
Wayne
