You can also double click on a powerdim that is set up how you want, and use
the apply to button to copy the settings to other ones.
Kent
"Dave Hinrichs" <_delete_dhinrichs@quannon.com> wrote in message
news:ECE6F895F4539995C439456AE1AD61BB@in.WebX.maYIadrTaRb...
> You can make Power Dims work like regular dims. In the Power Dialog where
> you specify the tolerance you can pick on the picture of the tolerance at
> the bottom. This will bring up a dialog that will allow you to choose a
type
> of tolerance. The ones labeled with (AutoCAD) will use the standard
AutoCAD
> dimensions tolerance settings. The others add the tolerance as text.
> Dave Hinrichs
> Quannon CAD Systems
> quannon.com
> Peer Hoffmann
wrote in message
> news:951BEC2049943FB1D818FBD170876543@in.WebX.maYIadrTaRb...
> > Jon
> > Use the good old AMDIMFORMAT (command line only) to make the tolerances.
> > Then use MATCHPROP from these.
> > I can't use MATCHPROP from Power Dim Tolerance types either.
