IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Matchprop and dim tolerences
16 REPLIES 16
Message 1 of 17
331 Views, 16 Replies
In MDT4, MATCHPROP would copy all tolerence settings from one dim to
another. In 5 it copies the upper and lower deviation values but doesn't
affect the tolerence type or whether or not the tolerence is displayed.
Is there a different way to copy tolerences between dims in version 5 or is
this a problem with my setup maybe?
(I am aware that I could use dimstyles but I would need too many different
ones to be practical)
Jon Crouch.
16 REPLIES 16
Message 2 of 17
Jon
Use the good old AMDIMFORMAT (command line only) to make the tolerances.
Then use MATCHPROP from these.
I can't use MATCHPROP from Power Dim Tolerance types either.
Peer
Jon C wrote in message
news:B83D3AC66F0A960E0F1D1B130167EBAA@in.WebX.maYIadrTaRb...
is
> Thanks,
> Jon Crouch.
Message 3 of 17
You can make Power Dims work like regular dims. In the Power Dialog where
you specify the tolerance you can pick on the picture of the tolerance at
the bottom. This will bring up a dialog that will allow you to choose a type
of tolerance. The ones labeled with (AutoCAD) will use the standard AutoCAD
dimensions tolerance settings. The others add the tolerance as text.
Dave Hinrichs
Quannon CAD Systems
quannon.com
Peer Hoffmann wrote in message
news:951BEC2049943FB1D818FBD170876543@in.WebX.maYIadrTaRb...
> Jon
> Peer
> is
different
> > Thanks,
> > Jon Crouch.
Message 4 of 17
You can also double click on a powerdim that is set up how you want, and use
the apply to button to copy the settings to other ones.
Kent
"Dave Hinrichs" <_delete_dhinrichs@quannon.com> wrote in message
news:ECE6F895F4539995C439456AE1AD61BB@in.WebX.maYIadrTaRb...
type
AutoCAD
> Dave Hinrichs
> Quannon CAD Systems
> quannon.com
> > Jon
Message 5 of 17
Dave and Kent
The question was about MATCHPROP (the format painter) and tolerances. I find
it much easier to 'Paint' from tolerances made with AMDIMFORMAT than to go
through two dialog boxes to achieve the same.
And you can't 'Paint' with any of the Power Dim tolerance types unless I'm
missing something.
Peer
Kent Keller wrote in message
news:096F8E75898DB3EC6E41A90FB95C416F@in.WebX.maYIadrTaRb...
use
> Kent
where
at
> type
> AutoCAD
> > Dave Hinrichs
> > Quannon CAD Systems
> > quannon.com
Message 6 of 17
Well I tried all the suggestions and I think the easiest way is a poweredit
using the '(AutoCAD)' tolerences and then using MATCHPROP.
It's a shame that tolerencing has become less streamlined in version 5. The
extra Settings dialog in Copy To and also the loss of the Preset Values
pulldown both make tolerencing unnecessarily tedious.
"Peer Hoffmann" wrote in message
news:10142FD5DA6E0108FBDDF0ED3D436D03@in.WebX.maYIadrTaRb...
> Dave and Kent
find
> missing something.
> Peer
> use
> > Kent
> where
> at
a
> > type
> > AutoCAD
> > > Dave Hinrichs
> > > Quannon CAD Systems
> > > quannon.com
Message 7 of 17
What am I missing then?
I am not able to use MATCHPROP on any Power Dim tolerance types, and I can't
control the color of the tolerances either. I'm stuck with yellow or green.
That is why I'm preferring AMDIMFORMAT where I can control it all.
Please advise,
Peer
news:0D08BF370F8C3E06DF11E47F500DD759@in.WebX.maYIadrTaRb...
poweredit
The
Message 8 of 17
news:E37C0970F534D15D2541774A5E422831@in.WebX.maYIadrTaRb...
can't
green.
> Please advise,
> Peer
Peer,
I have been following Dave's suggestion and creating AutoCAD tolerence types
using the AMPOWEREDIT dialog - PowerEdit an existing dim then go to 'Select
Tolerence Type' and use one of the two types with '(AutoCAD)' under them.
I'm pretty sure you cannot use MATCHPROP on PowerDim tolerence types.
Jon C
Message 9 of 17
types
'Select
That was my point exactly. AutoCAD tolerance types is a part of the PowerDim
tolerance types thus being unable to use MATCHPROP from them. Sorry if I
didn't explain that correctly. I'm a dane, so bear with me |8^(
Try making a toolbutton with the command: ^C^C_amdimformat and tell me if
you don't think it works better, AND you can use the Format Painter
(MATCHPROP) from these tolerances 8^))
Peer
Message 10 of 17
news:EA455CD75E9E50444742BA74743BDA62@in.WebX.maYIadrTaRb...
> types
> 'Select
them.
PowerDim
> Peer
I still don't think we're understanding each other. I am saying that you
_can_ use MATCHPROP on the '(AutoCAD)' type PowerDims.
It's hard to choose between AMPOWERDIM/EDIT and AMDIMFORMAT - I've been
using poweredit because I like to use the double-click feature as it saves
me from searching for buttons 🙂
Message 11 of 17
I AM obviously missing something. There must be some setting I'm not aware
of that allows you to do this and not me. I only get the dimcolor with the
painter, not the tolerances. I too would find it better to just
double-click, make the tol's, and use the painter on the rest of the dim's
that should have the same tol's. What are the steps to achieve this?
If you make your own button, you'll know where to find it, yes?
I've made these buttons that I can't live without:
AMDIMFORMAT
AMSETUPDWG
AMNOTE
AMLEGIBLE
Peer
Message 12 of 17
Peer
Here are the exact steps:
Dimension the view using AMREFDIM and/or AMPOWERDIM.
Double-click a dimension
Click 'Add Tolerence' and set the deviations
Click 'Choose Tolerence' Type and select one of the types with the label
'(AutoCAD)' written underneath.
OK, OK
MATCHPROP....
I'm sure this is exactly what you are doing already. The only thing I can
think of is the settings within the MATCHPROP command - I have everything
selected.
Good luck
Jon Crouch.
news:2C6A85180D455EE5A90909C8A5FA1307@in.WebX.maYIadrTaRb...
saves
> AMDIMFORMAT
> AMSETUPDWG
> AMNOTE
> AMLEGIBLE
> Peer
Message 13 of 17
news:C4E99AF892FE99720E96DC293A9E5F8C@in.WebX.maYIadrTaRb...
> Peer
> OK, OK
> MATCHPROP....
Just the dimcolors applies.
The only way I can get it right is using the 'Apply to >' button within the
Powerdim/edit dialog (works with all the tolerance types). But that is not
MATCHPROP.
> selected.
Me too - I give up.
Many thanks for your efforts,
Peer
Message 14 of 17
Peer
I am posting a small AVI to customer files that might give a visual clue??
Kent
news:4A1DBD60F69E6AC901B1585A2BD9CDA7@in.WebX.maYIadrTaRb...
> > Peer
Message 15 of 17
Wow, Kent
That really shed some light on the issue (8^D-)
I mistaked the two types underneath your selected tolerance type for being
AutoCAD tol. types (yellow and all) thus making me unable to use MATCHPROP.
I stand corrected and much advised. Don't know why this never crossed my
mind (8>(-)
Sorry for being so heavy minded (can you say that?).
THANKS,
Peer
P.S.: Sorry for all your trouble, Jon. I can see now why you didn't have a
clue as to what was going on here with me.
news:EAFEA479B1D76476576B987C11136BD7@in.WebX.maYIadrTaRb...
> Peer
> Kent
> > > Peer
Message 15 of 17
"Kent Keller" wrote in message
> Peer
> Kent
> > > Peer
Message 17 of 17
HyperCam http://www.hyperionics.com/index.html
I also use their FileBox Extender 8^)
The other program that I know of that does that, and might even be a little
better is Snagit from www.techsmith.com
Kent
