Since R14, a common method I've used to define an offset distance was to place the UCS on the workplane then [Offset] [Through] a [YZ] filtered Endpoint to a specific X value on a perpendicular part. Now in MDT6, when the view is anywhere but dead-on (ie. sketch view) I get some abstract value for X that only LOOKS to coincide with the endpoint I specified in the particular view where I was working from. I can measure correctly in X, I can move the feature to X after the offset but offset just doesn't work like it did...anyone else find this?
