Hi everyone.
I'm back on this topic for a new trial of MDT 2009 on windows 7.
I downloaded the PDS 2012 compatible version and i'm able to launch the setup. After configuration of the installation, I launch it, it installs visual C++ 2005 redistribuable, then direct X runtime, then starts MDT and crashes without any explanation but error 1603 in th elog.
I read again the beginning of this topic and make sure that everything was fine (unzipped in the same folder for example).
Dennis Jeffrey's link is dead so I can't see what it was.
I first thought it was a problem with .net framework 3.5 so I downloaded it from microsoft site and installed it, but it's still the same problem.
Now I can't see what I can do.
It's not a big problem for me because I don't use it but i'm trying to help my customer who has the same problem and same configuration (windows 7 pro SP1 64 bits with inventor 2013).
We both installed inventor 2012 in order to be able to install MDT20098 (otherwise the setup don't even start).
Any help would be appreciated. I will probably open a case in the autodesk support site if I don't have any solution here 😉
sorry can't help you, just to note Dennis passed away within the last yr or so, none of the links he provided over the years no longer works.
