Mechanical Desktop
*Dupre, Joe
Message 1 of 10 (59 Views)
How to add reference dim to invisible construction line?
59 Views, 9 Replies
09-20-2001 04:02 AM
How do I add an ordinal reference dim to a construction line that was used
when creating a feature?
For example, when creating a rectangular cutout in a panel I want to
dimension the "center" of the cutout, not the edges. I can do this with
construction lines when creating the sketch for the rectangular feature, but
the construction lines are obviously gone in the drawing view.
Is there any way to attach an arbitrary dimensionable reference point to a
feature? Any work-arounds?
- Joe
*Keller, Kent
Message 2 of 10 (59 Views)
Re: How to add reference dim to invisible construction line?
09-20-2001 04:21 AM in reply to: *Dupre, Joe
If you recreate the construction line in paperspace and annotate it you can dimension to
it. Some people make a small hole or notch at the middle of the feature to be able to
dimension off it. Or of course you can make the pardims visible in paperspace
Kent
"Joe Dupre" wrote in message
news:0574B5EADE4E2C76AB9ADB2EC466B4C6@in.WebX.maYIadrTaRb...
> Thanks,
> - Joe
*Keller, Kent
Message 3 of 10 (59 Views)
Re:
09-20-2001 04:30 AM in reply to: *Dupre, Joe
Actually I forgot, you can use mid snaps on amautodims now. run amautodim, choose
ordinate (I think that is what you mean?) and choose all the features except the 0.0
location. then use mid snap to place the 0.0
Kent
> > Thanks,
> > - Joe
*Dupre, Joe
Message 4 of 10 (59 Views)
Re:
09-20-2001 05:06 AM in reply to: *Dupre, Joe
"Kent Keller" wrote in message
news:7E343A4EE85202508E6BC5F208DFEFA4@in.WebX.maYIadrTaRb...
amautodim, choose
except the 0.0
Can you expand on this? I don't see quite how to do this (what objects to
pick and why). There isn't much documentation on AMAUTODIM that I could
find.
I don't know what this will look like once transmitted, but I have attempted
to create some ASCII art to show what I am attempting. Below shows a corner
of a panel, with an obround hole near the edge. How can I create a
horizontal ordinal dimension with the upper right corner being reference
(0.00), and dimensioning to the midpoint of the top of the obround? (Or
ideally the point that is midway between the two arcs, shown by the + in the
drawing.)
- Joe
______________
_________ |
(____+____) |
*Krech, Brad
Message 5 of 10 (59 Views)
Re:
09-20-2001 05:07 AM in reply to: *Dupre, Joe
If your trying to dimension to the center of a slot, the true center of the
slot that is, what I usually do is place a workpoint then sketch around that
workpoint and extrude the slot as a whole.
Then when you create views the parametric dimensions will appear.
Otherwise I use just regular Autocad linear dimensions and annotate them.
Good luck!
news:EFC6F84F1A4759BE405293C7BFC2331B@in.WebX.maYIadrTaRb...
> amautodim, choose
> except the 0.0
> find.
attempted
corner
the
> drawing.)
> - Joe
> ______________
> _________ |
> (____+____) |
*Keller, Kent
Message 6 of 10 (59 Views)
Re:
09-20-2001 05:59 AM in reply to: *Dupre, Joe
Joe
If you want the true Center, then try addins some small line or circle to the drawing view
as a annotation at the true center, and dimensioning to that. If the edge works for you
see the avi file I posted in customer fils
Kent
> amautodim, choose
> except the 0.0
> find.
> drawing.)
> - Joe
> ______________
> _________ |
> (____+____) |
*Dupre, Joe
Message 7 of 10 (59 Views)
Re:
09-20-2001 08:05 AM in reply to: *Dupre, Joe
Thanks Kent,
Where are the customer files? Is this a FTP site?
-Joe
news:179ECD8B5CD416195B7B65FBA4CAF4E7@in.WebX.maYIadrTaRb...
> Joe
the drawing view
works for you
> Kent
> > amautodim, choose
> > except the 0.0
to
> > find.
attempted
corner
the
> > drawing.)
> > - Joe
> > ______________
> > _________ |
> > (____+____) |
*Brown, Anne
Message 8 of 10 (59 Views)
Re:
09-20-2001 08:54 AM in reply to: *Dupre, Joe
Joe -
Customer Files is a discussion group for upload of problem files
for review. Please Zip any files prior to uploading to conserve
user download time and server space.
For NNTP newsgroup readers the Customer-files newsgroup can be
found at
news://discussion.autodesk.com/autodesk.autocad.customer-files.
You may also access the customer-files group via the HTTP
web-based forums at
http://discussion.autodesk.com/WebX?14@@.ee940b5.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Joe Dupre wrote:
> Thanks Kent,
*Russell, David
Message 9 of 10 (59 Views)
09-20-2001 10:30 PM in reply to: *Dupre, Joe
When I want to dim to the center of a cutout, I add a centerline, the refdim
to the centerline. Is this what you might be looking for?
David Russell
QED, Inc.
750 Enterprise Dr.
Lexington, Ky. 40510
ph. 859-231-0338
fx. 895-231-0376
e: jdr407@kih.net
but
> Thanks,
> - Joe
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.280 / Virus Database: 147 - Release Date: 9/11/2001
*Keller, Kent
Message 10 of 10 (59 Views)
Re:
09-21-2001 01:27 AM in reply to: *Dupre, Joe
Duhhh absolutely better than my suggestion of annotations. Boy this brain of mine is
due for a good flushing, it is getting a little gummed up I think
Kent
"David Russell" wrote in message
news:B61B3038D4D772B14DFE17D79AD614F7@in.WebX.maYIadrTaRb...
You are not logged in.
Manufacturing Community
Ask the Community
