Viqar,
No luck with the simplified version either.
Looks like I'll have to abandon the effort.
Thanks to all who tried.
Best regards,
Brian D. Verboort
Best Regards,
Brian D. Verboort
"Viqar Haider" wrote in message
news:6EF31B11EA7D2D4B33BD2C24DEEDAA93@in.WebX.maYIadrTaRb...
> Brian .
> Please let us know if you have any success doing FEA with this simplified
> solid.
> I tried it too but it completed only 3% overall in an hour and hung and
> then I had to cancel that...
> Viqar Haider
> "Johnson Shiue" wrote in message
> news:710BBC73FA5B2AA75C077846DCADBD11@in.WebX.maYIadrTaRb...
> > Brian,
> > AMFEA3D is a cool little tool for stress ananlysis. However, the meshing
> > capability is not as strong as other professional FEA packages. It does
> not
> > allow users fine-tuning meshes. Therefore, the model should not contain
> too
> > many small curvy faces. AMFEA3D will have problems in meshing Fillets or
> > chamfers. Actually, the stress analysis results does not make much
> > difference with or without fillets. I used AutoCAD SOLIDEDIT command to
> > delete all of the fillets on the model and reapplied constraints. Please
> go
> > to customer file area and find a message "To Brian Verboort." Please try
> the
> > model and see what you get. I believe AMFEA should work fine.
> > Let me know if you need more information.
> > Regards,
> > Johnson Shiue
> > Mechanical Market Group
> > autodesk.com
> > "Brian D. Verboort" wrote in message
> > news:29D5BEE5E8CFBCA5ABBAB596ECC89A05@in.WebX.maYIadrTaRb...
> > > All,
> > > I can't seem to get FEA to run on this frame assembly.
> > > See CF NG for file.
> > > Any ideas what I've done wrong?
> > > Best Regards,
> > > Brian D. Verboort
