Gary
I ran my toolbutton that does a amupdate L and then updates the scene, and finally the
drawing views, and it appeared to mostly fix it back up again. There is a couple of
balloons and dims between the top row of views and the bottom row.?? The dim is orphaned
along with one in one of the views. Not sure what the balloons and notes are doing out
there.
Kent
"Gary Cross" wrote in message
news:D5A5DD77F9899F255513380F91E5AFB1@in.WebX.maYIadrTaRb...
> Exploded views in Scenes are failing for no apparent reason. (see file in CF
> under same heading name)
> The Scene is set up with an explosion factor & tweaks are made, the views
> are created & balloons added. I make an edit to one part (added a thread)
> &, voila...chaos.
> After many hours of work, the most of the assembly collapses together again
> with a few trails haplessly floating about the assembly. An external
> subassembly, however, remains properly exploded.
> I get following at the command prompt in Drawing mode:
> "10 drawing views being updated.
> Solve failed, please use amupdate assembly to correct this.Solve failed,
> please
> use amupdate assembly to correct this.Solve failed, please use amupdate
> assembly to correct this.Solve failed, please use amupdate assembly to
> correct
> this.
> But, doing amupdates has no affect either in Scene mode model mode or
> drawing mode.
> This behavior makes scenes & exploded views worthless. I can't complete my
> projects ( read "no income") with this happening.
> Anyone else experiencing this behavior? Any antidotes?
> Gary Cross
> gcross@crossdesign.com
