Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
ERROR - Please Help !!!!!!!!!!!!!!!
7 REPLIES 7
Message 1 of 8
1993 Views, 7 Replies
Gerald
Is this new behavior (I would hope so).
Check the temp directory and clean it out. Maybe do a cold reboot on the
computer.
bought all I can come up with off the top of my head.
Kent Keller
Strobe Data Inc.
www.strobedata.com
All wiyht. Rho sritched mg kegtops awound?
Willyoupleasehelpmefixmykeyboard?Thespacebarisbroken!
"Gerald Marlin" wrote in message
news:87uu8c$m4m17@adesknews2.autodesk.com...
> unhandled access violation reading 0x0070 exception at 565507eeh, then it
> says- error handler re-entered. exit now.
> been getting this message on and off for a few hours, in different files ,
> and it kicks me clear out of MDT4
7 REPLIES 7
Message 2 of 8
Message 3 of 8
Well not really new, just more often. I get some kind of fatal error at
least 2 to 3 times a day. But this one is really beginning to bug me.
I'm running a Micron Millennia Max GS133, 256 RAM, P3 600, NT4, MDT4
Message 4 of 8
Is there a common thread to the crashes like doing view functions or are
they random.
If you run your computor in VGA mode do you still have problems?
Have you made sure the video driver is the latest available off the web.
Dave Hinrichs, Quannon CAD Systems
http://www.quannon.com/
My email address has been altered remove
the _delete_ to make it work, sorry.
Gerald Marlin wrote in message
news:87v0m3$m4123@adesknews2.autodesk.com...
Message 5 of 8
Gerald,
Have you reapplied your NT service pack recently? Or have you considered upping
to the next NT SP if your not already on 6a?
How much swap file is set in NT? 3x your RAM should be a minimum!
- Drew
Gerald Marlin wrote:
> It seems to be random, I've been looking for a common thread to this problem
> but I don't think there is one.
> And I installed the current drivers last week.
Drew Fulford B.A.Sc. Systems Engineer
Solid Caddgroup Inc. Burlington, Ontario
Tel: (905)331-9670, Fax: (905)331-7280
Visit my MCAD website @ http://webhome.idirect.com/~dfulford/
Message 6 of 8
Message 7 of 8
Aslo make sure you keep your \temp directory clean.
news:87v4us$m4234@adesknews2.autodesk.com...
problem
Message 8 of 8
212411015
I have the same problem when i want to add materials in autocad .. if i clike ok autocad stopped
please help 😞
