IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Dumb question....Unigraphics "reference sets"???
7 REPLIES 7
Message 1 of 8
4667 Views, 7 Replies
A few years ago I worked for a company who used Unigraphics....anyone familiar with this software? With Unigraphics you could set up "reference sets".... Within an assembly drawing, one could select a part or group of parts as as "set" (for instance, the rear section of a car frame) ....this set could be brought into an upper assembly,(for example, axle installation) eliminating the need to load more parts than needed ( say, the entire car frame). Multiple reference sets could be set up,(example...rear frame, front frame, mid frame...etc) allowing different upper assembly drawings to show different parts of the same assembly without having to load the entire assembly. Does what I have said make sense to you? If any of you have used Unigraphics, I am sure it does. Is there any way to do this in MDT?
Mike
michaelbrainard@hotmail.com
7 REPLIES 7
Message 2 of 8
Mike,
I've never actually used Unigraphics, but don't
subassemblies do the same?
Ray
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
A
Mike
Message 3 of 8
Yes and no.....for example....you are showing the installation of a small item....maybe a fuel filter...mounted under the frame of your car....you only need to show the left frame rail to show the location of the filter. One reference set inside the "frame" assembly would be called "frame rail - filter location" or whatever you wanted to call it. When you insert the frame assembly you would select the reference set you want in your upper assembly. One argument to this might be to only insert the frame rail.....not the entire frame. True...but depending on the assembly structure, this would FUBAR the bill of materials...because the filter is bolted to the "Frame upper assembly"....not just the frame rail. Or you may need to show multiple parts of an assembly to reference the location of the filter...say the frame rail and a cross member..... Make a bit of sense at all? I think it is Monday again......
Message 4 of 8
Never tried it with MDT parts, but you might look at the
group command. It's an AutoCAD command but might work for you.
Ray
Yes
again......
Message 5 of 8
Mike,
There is NO such feature in MDT6 and none in IV
either. This is one of the biggest shortcomings in the two packages
IMHO.
The only workaround that come in mind
are:
- make heavy use of a clever subassembly
structure
- in MDT, perform xref/unload on subassemblies you
don't need at the moment
Both methods are far from the power of reference
sets (or configurations as named by others...)
Leo Laimer
Maschinen-
und Fertigungstechnik
A-4820 Bad Ischl - Austria
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
A
Mike
Message 6 of 8
structure
MDT's restructure command is a godsend for this.
Pity Inventor still sucks at the same thing...
Mike,
IMHO.
are:
structure
you don't need at the moment
Leo
Laimer
Maschinen- und Fertigungstechnik
A
Mike
Message 7 of 8
steveoliver
ok i might not of read this properly but wont scenes do what you want? create a scene and the make different parts visible? im probably wrong.... usually am 😉
Message 8 of 8
I hope somebody will reply after 9 years :))
I have a Dumb question to your Dumb question: What are the reference sets in UG NX, I work at a project in UG NX Electrical Routing and I am stuck, I dont know how to work with refernce sets, what they are and what they do.
