IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Does Vault Professional 2012 Works with Autodesk Mechanical Desktop?
1 REPLY 1
fmendizabal
517 Views, 1 Reply
Since MDT last release is 2009, is posible to work with the latest Vault version (2012)?. We want to implement Vault in the company and migrate to Inventor, depending on the MDT integration with Vault will influence the Process, for example: migrating first all MDT files, work with Inventor and later implement Vault, however, will be a longer time frame.
Does someone has migrated from MDT to Inventor and Vault recently?
Tags (3)
1 REPLY 1
mikel_martin
in reply to: fmendizabal
One solution is to use the Auto-loader application that is installed with Vault to load the MDT files.
Then download as needed to migrate the files to Inventor.
This will allow to have a single source for data as you transition.
Mikel Martin
User Experience Architect
Autodesk, Inc.
