Announcements
IMPORTANT. Forum to be archived in several phases. You can no longer submit new questions - but can only answer existing threads until Oct 17th 2016. Please read this message for details
Mechanical Desktop (Read Only)
Curved edges of object not showing up in drawing in paperspace
17 REPLIES 17
Message 1 of 18
286 Views, 17 Replies
My problem is this: the radii portion of a formed object will not appear
in the views in my drawing. In the orthographic views, where ever the
radius resides, there is nothing. In section views of the object, there
isn't even any hatch. This happens at all levels of my assembly with this
part. Any ideas, other than blowing the entire part and starting over?
17 REPLIES 17
Message 2 of 18
Have you checked off "show tangencies" (on view
display tab)?
darvin
Message 3 of 18
It isn't the tangencies that aren't
showing........the actual outer edges of the object won't show in orthographic
views ( curved outer surfaces )....where ever the object is straight shows
up.  Isometric views look fine.  Section views of my orthographic
views do not show the object at all....no hatch either. Turning on the
tangencies does not good....
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
display tab)?
darvin
Message 4 of 18
Show tangencies has always done it for me! You
might want to past a sample to verify it's not a display issue. maybe a "layer
frozen/off" issue?
darvin
Message 5 of 18
I have turned on and unfrozen every
layer.....  There is something wrong with the ambend feature.  I
suppress the feature and the object appears correctly....unsuppressed and I have
ghost parts.
Here is the whole story:
This part starts as a .75" thick panel, 12"  x
60" approximately.  In it's flat state I have placed several features in
it.....4 4" dia holes, and an array of "curfs" on the back side (.25 x .625 cut
through.....approx 40 total) and saw cuts on all edges for an assembly
spline.  Then I created a new drawing file...a new part (dummy part...no
objects) to represent the part in its curved state....used amcombine and then
applied the ambend to show the part in its formed state.  It is at this
level that I have problems.  Confused?  Are all the other features in
this part to complex for the ambend feature?  The part looks great in model
space.....
frozen/off" issue?
darvin
Message 6 of 18
I'm always a little <G> confused. But if
itshows in MS it should show in PS. Try inserting it into an assy and starting
from a Scene based view or a Selection Set view. I have seen a difference but
don't know why. AMbend should not hinder a drawing view.
darvin
Message 7 of 18
Darvin...
I almost always start from selection based
view.  The parts in question here are externalized as piece parts (there
are two)....these parts are pulled into a panel assembly...then pulled into an
upper level assembly.  The problem occurs at all levels. I tried to create
views from a scene....same problem.  I still don't get why isometric views
look ok.  If I create a base view with my object at a random angle
(using 3dorbit create the angle I wish) some of the lines show....depends on the
angle of the view?
darvin
Message 8 of 18
Well, I'm baffled. If you want to post or e-mail
the part, I'll see what it looks like here.
darvin
Message 9 of 18
Michael,
Are these complicated parts? Sounds like there may be a problem with the
entities.
A few things to try....
AMSANITYCHECK
Set AMFEATCHK to 63 and force an update on the part (AMUPDATE > ALL).
Export a .stp, read it back in, see if everything looks ok and do another
sanity check.
Jeff
"Michael Brainard" wrote in message
news:78D6F67B661E074A64EC58887E9C3B0C@in.WebX.maYIadrTaRb...
Darvin...
I almost always start from selection based view. The parts in question here
are externalized as piece parts (there are two)....these parts are pulled into
a panel assembly...then pulled into an upper level assembly. The problem
occurs at all levels. I tried to create views from a scene....same problem. I
still don't get why isometric views look ok. If I create a base view with my
object at a random angle (using 3dorbit create the angle I wish) some of the
lines show....depends on the angle of the view?
Message 10 of 18
This is what amsanity check gives me....now what? !
entid 1619D358: Error: internal position on coedge off face
coedge parameter = 0.673921
dist = 0.000007
curve loc = ( -40.703994131737, -118.92411006022, -3.4330385693166 )
face loc = ( -40.703990095082, -118.9241047676, -3.4330363096303 )
coedge parameter = 0.675167
dist = 0.000007
curve loc = ( -40.705618231402, -118.92248101634, -3.4339481003408 )
face loc = ( -40.705614178517, -118.92247571561, -3.4339458312048 )
coedge parameter = 0.676413
dist = 0.000007
curve loc = ( -40.707240521911, -118.92084961948, -3.4348567642813 )
face loc = ( -40.707236452761, -118.92084431067, -3.4348544856727 )
coedge parameter = 0.677659
dist = 0.000007
curve loc = ( -40.708861000747, -118.91921587219, -3.4357645597275 )
face loc = ( -40.708856915284, -118.91921055529, -3.435762271618 )
coedge parameter = 0.678905
dist = 0.000007
curve loc = ( -40.710479665393, -118.91757977698, -3.4366714852699 )
face loc = ( -40.710475563562, -118.917574452, -3.4366691876257 )
coedge parameter = 0.680151
dist = 0.000007
curve loc = ( -40.712096513336, -118.91594133641, -3.4375775395006 )
face loc = ( -40.712092395072, -118.91593600333, -3.4375752322823 )
coedge parameter = 0.681397
dist = 0.000007
curve loc = ( -40.713711542067, -118.91430055302, -3.4384827210129 )
face loc = ( -40.713707407294, -118.91429521181, -3.4384804041755 )
coedge parameter = 0.682643
dist = 0.000007
curve loc = ( -40.715324749078, -118.91265742936, -3.4393870284017 )
face loc = ( -40.715320597709, -118.91265207997, -3.4393847018943 )
coedge parameter = 0.683889
dist = 0.000007
curve loc = ( -40.716936131864, -118.91101196797, -3.440290460263 )
face loc = ( -40.716931963803, -118.91100661035, -3.4402881240291 )
entid 0B7E6480: Error: internal position on coedge off face
coedge parameter = 0.661461
dist = 0.000168
curve loc = ( -40.687654187637, -118.94027053084, -3.4238958807811 )
face loc = ( -40.687736261365, -118.94027053084, -3.4237490289042 )
coedge parameter = 0.662707
dist = 0.000169
curve loc = ( -40.689296239717, -118.9386651552, -3.4248140047596 )
face loc = ( -40.68937846266, -118.9386651552, -3.4246669097993 )
coedge parameter = 0.663953
dist = 0.000169
curve loc = ( -40.690936507982, -118.93705740146, -3.425731275835 )
face loc = ( -40.69101887813, -118.93705740146, -3.4255839414402 )
coedge parameter = 0.665199
dist = 0.000169
curve loc = ( -40.692574989884, -118.93544727211, -3.4266476925831 )
face loc = ( -40.692657505429, -118.93544727211, -3.4265001220456 )
coedge parameter = 0.666445
dist = 0.000169
curve loc = ( -40.69421168288, -118.93383476966, -3.4275632535813 )
face loc = ( -40.69429434221, -118.93383476966, -3.4274154498349 )
coedge parameter = 0.667691
dist = 0.000170
curve loc = ( -40.69584658443, -118.93221989661, -3.4284779574081 )
face loc = ( -40.695929386132, -118.93221989661, -3.4283299230292 )
coedge parameter = 0.668937
dist = 0.000170
curve loc = ( -40.697479691995, -118.93060265547, -3.4293918026435 )
face loc = ( -40.697562634857, -118.93060265547, -3.4292435398506 )
coedge parameter = 0.670183
dist = 0.000170
curve loc = ( -40.699111003039, -118.92898304874, -3.4303047878688 )
face loc = ( -40.699194086048, -118.92898304874, -3.4301562985226 )
coedge parameter = 0.671429
dist = 0.000170
curve loc = ( -40.70074051503, -118.92736107895, -3.4312169116666 )
face loc = ( -40.700823737373, -118.92736107895, -3.4310681972696 )
coedge parameter = 0.672675
dist = 0.000171
curve loc = ( -40.702368225438, -118.9257367486, -3.4321281726207 )
face loc = ( -40.702451586502, -118.9257367486, -3.4319792343178 )
dist = 0.000171
face loc = ( -40.704077631108, -118.92411006022, -3.4328894078941 )
dist = 0.000171
face loc = ( -40.705701868867, -118.92248101634, -3.4337987162271 )
dist = 0.000171
face loc = ( -40.707324297459, -118.92084961948, -3.4347071575464 )
dist = 0.000172
face loc = ( -40.708944914564, -118.91921587219, -3.4356147300829 )
dist = 0.000172
face loc = ( -40.710563717868, -118.91757977698, -3.4365214320689 )
dist = 0.000172
face loc = ( -40.71218070506, -118.91594133641, -3.437427261738 )
dist = 0.000173
face loc = ( -40.71379587383, -118.91430055302, -3.4383322173248 )
dist = 0.000173
face loc = ( -40.715409221871, -118.91265742936, -3.4392362970655 )
dist = 0.000173
face loc = ( -40.717020746882, -118.91101196797, -3.4401394991975 )
entid 1619D760: Error: internal position on coedge off face
coedge parameter = -0.683753
dist = 0.000355
curve loc = ( -51.141410995386, -118.91291294576, -13.864877619021 )
face loc = ( -51.141101006292, -118.91291294576, -13.865051338167 )
coedge parameter = -0.681054
dist = 0.000354
curve loc = ( -51.14336952785, -118.91646783982, -13.868375156026 )
face loc = ( -51.14306039804, -118.91646783982, -13.868548333737 )
coedge parameter = -0.678355
dist = 0.000353
curve loc = ( -51.1453321199, -118.92001174117, -13.871881237964 )
face loc = ( -51.145023886258, -118.92001174117, -13.872053853789 )
coedge parameter = -0.675657
dist = 0.000352
curve loc = ( -51.147298757245, -118.92354462398, -13.875395839303 )
face loc = ( -51.14699145301, -118.92354462398, -13.875567874853 )
coedge parameter = -0.672958
dist = 0.000351
curve loc = ( -51.149269425564, -118.92706646253, -13.878918934449 )
face loc = ( -51.148963080333, -118.92706646253, -13.879090373391 )
coedge parameter = -0.670260
dist = 0.000350
curve loc = ( -51.151244110504, -118.93057723117, -13.882450497746 )
face loc = ( -51.150938750236, -118.93057723117, -13.882621325805 )
coedge parameter = -0.667561
dist = 0.000349
curve loc = ( -51.153222797686, -118.93407690434, -13.885990503474 )
face loc = ( -51.1529184447, -118.93407690434, -13.886160708426 )
coedge parameter = -0.664863
dist = 0.000348
curve loc = ( -51.155205472699, -118.93756545655, -13.889538925855 )
face loc = ( -51.154902145678, -118.93756545655, -13.889708497524 )
coedge parameter = -0.662164
dist = 0.000346
curve loc = ( -51.157192121107, -118.94104286239, -13.893095739048 )
face loc = ( -51.156889835099, -118.94104286239, -13.893264669302 )
coedge parameter = -0.659465
dist = 0.000345
curve loc = ( -51.15918272844, -118.94450909655, -13.896660917151 )
face loc = ( -51.158881494861, -118.94450909655, -13.896829199898 )
coedge parameter = -0.656767
dist = 0.000344
curve loc = ( -51.161177280203, -118.94796413377, -13.900234434201 )
face loc = ( -51.160877106837, -118.94796413377, -13.900402065384 )
coedge parameter = -0.654068
dist = 0.000343
curve loc = ( -51.163175761871, -118.9514079489, -13.903816264174 )
face loc = ( -51.162876652874, -118.9514079489, -13.90398324177 )
coedge parameter = -0.651370
dist = 0.000341
curve loc = ( -51.165178158889, -118.95484051687, -13.907406380986 )
face loc = ( -51.164880114793, -118.95484051687, -13.907572704999 )
coedge parameter = -0.648671
dist = 0.000340
curve loc = ( -51.167184456677, -118.95826181266, -13.911004758493 )
face loc = ( -51.166887474387, -118.95826181266, -13.91117043095 )
coedge parameter = -0.645972
dist = 0.000339
curve loc = ( -51.169194640623, -118.96167181137, -13.914611370491 )
face loc = ( -51.168898713426, -118.96167181137, -13.914776395438 )
coedge parameter = -0.643274
dist = 0.000338
curve loc = ( -51.171208696089, -118.96507048817, -13.918226190713 )
face loc = ( -51.170913813652, -118.96507048817, -13.918390574212 )
coedge parameter = -0.640575
dist = 0.000336
curve loc = ( -51.173226608407, -118.9684578183, -13.921849192837 )
face loc = ( -51.172932756783, -118.9684578183, -13.922012942959 )
coedge parameter = -0.637877
dist = 0.000335
curve loc = ( -51.175248362882, -118.9718337771, -13.925480350478 )
face loc = ( -51.174955524511, -118.9718337771, -13.925643477299 )
coedge parameter = -0.635178
dist = 0.000334
curve loc = ( -51.177273944792, -118.97519833997, -13.929119637192 )
face loc = ( -51.176982098505, -118.97519833997, -13.929282152792 )
entid 1618E838: Error: internal position on coedge off face
coedge parameter = -0.239837
dist = 0.000026
curve loc = ( -51.535640162848, -119.35148118275, -14.594920477942 )
face loc = ( -51.535617267165, -119.35148118275, -14.594932405766 )
coedge parameter = -0.233471
dist = 0.000026
curve loc = ( -51.541272959611, -119.35448055434, -14.605738437484 )
face loc = ( -51.541249967702, -119.35448055434, -14.605750402327 )
coedge parameter = -0.227104
dist = 0.000026
curve loc = ( -51.546909258785, -119.35740120467, -14.616575443859 )
face loc = ( -51.546886353234, -119.35740120467, -14.616587350687 )
coedge parameter = -0.220738
dist = 0.000026
curve loc = ( -51.552548831912, -119.36024301536, -14.627431057808 )
face loc = ( -51.552526173577, -119.36024301536, -14.627442823179 )
coedge parameter = -0.214371
dist = 0.000025
curve loc = ( -51.558191450399, -119.36300587123, -14.638304839315 )
face loc = ( -51.558169178947, -119.36300587123, -14.63831639106 )
coedge parameter = -0.208004
dist = 0.000025
curve loc = ( -51.563836885534, -119.36568966029, -14.649196347632 )
face loc = ( -51.56381511997, -119.36568966029, -14.649207624522 )
coedge parameter = -0.201638
dist = 0.000024
curve loc = ( -51.569484908488, -119.36829427376, -14.660105141287 )
face loc = ( -51.569463747703, -119.36829427376, -14.660116092713 )
coedge parameter = -0.195271
dist = 0.000023
curve loc = ( -51.575135290328, -119.37081960606, -14.671030778112 )
face loc = ( -51.57511481364, -119.37081960606, -14.671041363751 )
coedge parameter = -0.188905
dist = 0.000022
curve loc = ( -51.580787802024, -119.37326555483, -14.681972815254 )
face loc = ( -51.580768069732, -119.37326555483, -14.681983004744 )
coedge parameter = -0.182538
dist = 0.000021
curve loc = ( -51.586442214462, -119.37563202093, -14.692930809195 )
face loc = ( -51.5864232684, -119.37563202093, -14.692940581805 )
coedge parameter = -0.176171
dist = 0.000020
curve loc = ( -51.592098298449, -119.37791890845, -14.703904315771 )
face loc = ( -51.592080162545, -119.37791890845, -14.703913660068 )
coedge parameter = -0.169805
dist = 0.000019
curve loc = ( -51.597755824726, -119.38012612467, -14.71489289019 )
face loc = ( -51.597738505565, -119.38012612467, -14.714901803709 )
coedge parameter = -0.163438
dist = 0.000019
curve loc = ( -51.603414563974, -119.38225358014, -14.725896087047 )
face loc = ( -51.603398051367, -119.38225358014, -14.72590457596 )
coedge parameter = -0.157072
dist = 0.000018
curve loc = ( -51.609074286825, -119.38430118863, -14.736913460346 )
face loc = ( -51.609058554382, -119.38430118863, -14.736921539128 )
coedge parameter = -0.150705
dist = 0.000017
curve loc = ( -51.614734763871, -119.38626886714, -14.747944563517 )
face loc = ( -51.614719769575, -119.38626886714, -14.747952254614 )
coedge parameter = -0.144339
dist = 0.000016
curve loc = ( -51.620395765676, -119.38815653591, -14.758988949432 )
face loc = ( -51.620381452463, -119.38815653591, -14.758996282926 )
coedge parameter = -0.137972
dist = 0.000015
curve loc = ( -51.626057062779, -119.38996411843, -14.770046170425 )
face loc = ( -51.626043359124, -119.38996411843, -14.770053183704 )
coedge parameter = -0.131605
dist = 0.000015
curve loc = ( -51.631718425709, -119.39169154143, -14.781115778309 )
face loc = ( -51.631705246209, -119.39169154143, -14.781122515731 )
coedge parameter = -0.125239
dist = 0.000014
curve loc = ( -51.637379624992, -119.39333873489, -14.792197324398 )
face loc = ( -51.63736687096, -119.39333873489, -14.792203836956 )
entid 0A991158: Error: ellipse normal not perpendicular to major_axis
entid 0B796E10: Error: start vertex not on curve
edge id 0A991158 (ellipse)
vertex loc = (-40.686088419692, -118.94186832576, -3.4228281470835)
near_pos = (-40.68601034276, -118.94187353711, -3.4229768988797)
dist 1.680781e-004
entid 0B796230: Error: end vertex not on curve
vertex loc = (-40.718626261442, -118.90935880495, -3.4410394776008)
near_pos = (-40.718545675915, -118.90936418372, -3.4411930084595)
dist 1.734782e-004
entid 0A991158: Error: edge start param err
entid 0A991158: Error: edge end param err
entid 0BA6C0C8: Error: ellipse normal not perpendicular to major_axis
entid 0B790AF0: Error: start vertex not on curve
edge id 0BA6C0C8 (ellipse)
vertex loc = (-51.139140617942, -118.90935880495, -13.861553775741)
near_pos = (-51.139456567504, -118.90934714107, -13.86138870727)
dist 3.566620e-004
entid 0B7B75E8: Error: end vertex not on curve
vertex loc = (-51.179008198245, -118.97856242462, -13.932921290337)
near_pos = (-51.179303367241, -118.97855152834, -13.932767076553)
dist 3.332047e-004
entid 0BA6C0C8: Error: edge start param err
entid 0BA6C0C8: Error: edge end param err
entid 0AD92EF8: Error: ellipse normal not perpendicular to major_axis
entid 0B7E0990: Error: start vertex not on curve
edge id 0AD92EF8 (ellipse)
vertex loc = (-51.529988296054, -119.34840496221, -14.584133393194)
near_pos = (-51.530011097915, -119.34840321211, -14.584122005841)
dist 2.554720e-005
entid 0B7EA210: Error: end vertex not on curve
vertex loc = (-51.643027937777, -119.39490658831, -14.803296600593)
near_pos = (-51.643040431161, -119.39490563205, -14.803290359517)
dist 1.399822e-005
entid 0AD92EF8: Error: edge start param err
entid 0AD92EF8: Error: edge end param err
checked:
1 lumps
1 shells
0 wires
410 faces
413 loops
2406 coedges
1203 edges
798 vertices
checked:
1 lumps
1 shells
0 wires
399 faces
402 loops
2364 coedges
1182 edges
788 vertices
checked:
1 lumps
1 shells
0 wires
3 faces
4 loops
4 coedges
2 edges
"Jeff Howard" wrote in message
news:1325FB8472CB3B5DDB6D05924342FF29@in.WebX.maYIadrTaRb...
> Michael,
> entities.
> AMSANITYCHECK
> sanity check.
> Jeff
> Darvin...
here
into
problem. I
my
the
Message 11 of 18
The problem occurs when I apply the ambend to the part....
Message 12 of 18
Patient: "Doc, it hurts when I do this."
Doctor: "Well, don't do that!"
Sorry, can't offer much advice. If you can post the part to CF someone may be
able to offer suggestions.
Jeff
news:f118cab.9@WebX.maYIadrTaRb...
Message 13 of 18
Creating the .stp file and importing it back in did not good either. Part
looks fine in model space....paper space it still won't show certain
entities, even as a base solid!
Message 14 of 18
    Got to be an mdt PS problem.
Acis out file displays fine in spacial's acis viewer and pastes in and displays
fine in word. Just can't get hidden line view to display properly in mdt
PS.
    I'm baffled, just took a look in
a newer version of the hoops viewer and there are definitely some unexpected
lines and triangles. it might be the cuts in the edges? They don't seem to
take a curve. I'll try some experiments later, when i've got a little more
time.
darvin
Message 15 of 18
Michael,
Edit the view that is questionable in Paper Space and get rid of the
check mark in the "Remove Coincidant Edges" this should solve your
problem.
Greg
Message 16 of 18
Greg,
Sorry, no dice...
To get this to work, I had to eliminate the ambend from the combined
part....go back the the flat part and apply the ambend there. Eliminate the
amcombine and the part looks fine.....
Mike
"Greg Abel" wrote in message
news:3db41e09.4873788@DISCUSSION.AUTODESK.COM...
> Michael,
> problem.
> Greg
Message 17 of 18
Michael,
Opps, that just pacifies the problem , does not fix it...if you turn
on hidden lines and remove the check mark from "remove coincident
edges" if show up fine, however, when you suppress the bend feature,
everything shows up and works just fine too as you said. Weird, not
sure what is going on?
Greg
Message 18 of 18
The. lines that should be shown on the am_vis layer are dumped into the
am_hid layer. So, just for fun I tried to modify the edge properties of a
screwed up view....I turned ON the hidden lines.....selected one of the
hidden lines that should be visible....changed it from the am_hid layer to
the am_vis layer......should show up then, right? WRONG.....still isn't
visible......
news:3db425d5.6869748@DISCUSSION.AUTODESK.COM...
> Michael,
> Greg
