Somewhat less confused, since I don't know what is happening between the
inner angled surfaces. Back to you original question; however, have you
considered using the edges of the first extrusion for the second profile
rather than copying the sketch? Then both extrusions will update with any
changes to the first sketch.
Ray
"Walter Pfohl" wrote in message
news:A154C55462412E74257400E64BAA2551@in.WebX.maYIadrTaRb...
> Let me show you!
> The feature is identical between the two angular planes.
> Walter
> Ray Dyson wrote in message
> news:78EF4BB4E496B8AB713C2508787018BB@in.WebX.maYIadrTaRb...
> > Walter,
> > You lost me, no surprise.
> > You have a sketch on a sketchplane that you want to extrude to a plane
> that
> > lies near you and to a plane that lies away from you, yes? If no, then
I'm
> > confused.
> > Ray
> > news:9A41C44217F736B0E211CE48498D7B74@in.WebX.maYIadrTaRb...
> > > I need to do that on both sides of a c/l. If I could extrude > To-From
> > > plane-plane & plane-plain I would be all set.
> > > Walter
> > > news:0792876E902C252A1FFA9C322DFB16C6@in.WebX.maYIadrTaRb...
> > > > Extrude >To-From> plane-plane??
> > > > Ray
> > > > news:79EC5201755265D44FCB8291791F9AF4@in.WebX.maYIadrTaRb...
> > > > > I had to extrude it between two non parallel planes. I can not do
> that
> > > (2)
> > > > > times.
> > > > > Walter
> > > > > Glenn Freeman wrote in message
> > > > > news:E0BBA0C437D3FAAACD1F0F646521F344@in.WebX.maYIadrTaRb...
> > > > > > You could just constrain a new sketch to the original after you
> have
> > > > done
> > > > > > the original extrusion. That way if you change the original
> > extrusion
> > > > > both
> > > > > > with change.
> > > > > > You could also do an extrusion with the type as midplane and
give
> > the
> > > > > total
> > > > > > distance of the extrusion. MDT will automatically go 1/2 the
> > distance
> > > > in
> > > > > > each direction.
> > > > > > Glenn Freeman
> > > > > > news:97551BFB2CB69E49F9BF898B1F7DAEC5@in.WebX.maYIadrTaRb...
> > > > > > > Kent,
> > > > > > > I had a part that had the same feature symetrical about a C/L
> and
> > > thus
> > > > I
> > > > > > > needed the same sketch extruded both ways.
> > > > > > > Walter
> > > > > > > Kent Keller wrote in message
> > > > > > > news:538D0EBABDB3A9EAC73389E25A9DFFA1@in.WebX.maYIadrTaRb...
> > > > > > > > It asks for the center, so if you had a rectangle for
> instance,
> > > > before
> > > > > > > doing the
> > > > > > > > copysketch, draw a angled line from corner to corner, and
then
> > > when
> > > > it
> > > > > > > asks for the
> > > > > > > > center, snap to the middle of this line. Or you could use
> > > > something
> > > > > > > like this
> > > > > > > > toolbutton I use _non;'cal;(cur+cur)/2;^M; that allows
you
> to
> > > > pick
> > > > > > the
> > > > > > > two corners, and
> > > > > > > > it returns the mid point.
> > > > > > > > I have to ask though, why do you want two sketches in the
same
> > > > > location?
> > > > > > > > Kent
> > > > > > > news:f08346c.-1@WebX.maYIadrTaRb...
> > > > > > > > > Is there a way to copy a sketch to the exact location it
> > started
> > > > at?
> > > > > > > > > Walter
