Mechanical Desktop
Member
brwi85
Message 1 of 1 (277 Views)
Constant errors and failures with old mechanical desktop files. Please Help!
277 Views, 0 Replies
06-18-2013 03:18 PM
With my new job, I inherited a very large collection of old 3d files, all of our old projects.
Ive switched to inventor for all current projects, but once a month or so i get an old part number floating in, and I have to dig into the old .DWG files.
I have Mechanical desktop 2009 alongside my Inventor 2012 install. I usually attempt to import first, sometimes it works, but many times it doesnt.
First error on opening one of these old files:
It says "opening R14 file" Then pops up with this error:
AutoCAD Error Aborting
FATAL ERROR: Unhandled Access Violation Reading 0x4418 Exception at 49259ffeh
Then it hangs on "Auditing mechanical data" on the MDT side, and Import "initializing" on the inventor side, then I have to force close both programs.
The other common error, seen when you open the file from windows explorer is :
Exception in acme.arx ARX Command
Unhandled Exception FFFFFFFFC0000005 (Access Violation Reading 0x4418) at address 49259FFEh
We have a ton of data in these old files, and I need to be able to access them.
Ive been able to see enough of the material list to open the individual files, and reverse engineer the product usually, but there has to be a way to get these old files open without errors.
Ill attach the offending file that i ran into today. It is the top level assembly, with other files below it.
You are not logged in.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
Ask the Community
