Maya LT Forum
Welcome to Autodesk’s Maya LT Forums. Share your knowledge, ask questions, and explore popular Maya LT topics.
Removing n-gons - selecting edge and vertex in face select mode?
2 REPLIES 2
1462 Views, 2 Replies
Hi in this spot in the jetpack tutorial video
http://youtu.be/lLBDXbnmQnQ?t=11m59s
it is in the face select multi-component mode but she is selecting a vertex and an edge at the same time and using "connect". I can't figure out how to do that....
2 REPLIES 2
MatthewDoyleArt
  1. Don't turn Connect on yet. It should not be highlighted blue.
  2. Now - with Multi-Component mode enabled - select the vert (it will turn yellow).
  3. Hold Shift on your keyboard and sleect the edge (it will turn orange).
  4. Now press Connect.
_______________________________________________________________________________
Check out my LIVE Twitch Feed: www.twitch.tv/matthewdoyle
...for live workflows using Mudbox, Maya LT, MotionBuilder, Sketchbook, 3ds Max and more.
1 PM - 6 PM CST - Monday - Friday
in reply to: MatthewDoyleArt
Thanks I wasn't aware that multi-component mode could let you choose between vertices, edges and faces depending on what item you were closest to. I thought you had to be in a single mode at once.
