Hi in this spot in the jetpack tutorial video
http://youtu.be/lLBDXbnmQnQ?t=11m59s
it is in the face select multi-component mode but she is selecting a vertex and an edge at the same time and using "connect". I can't figure out how to do that....
Solved by MatthewDoyleArt. Go to Solution.
Thanks I wasn't aware that multi-component mode could let you choose between vertices, edges and faces depending on what item you were closest to. I thought you had to be in a single mode at once.
