Greetings, I purchased a subscription to maya LTthtough steam, and noticed some of the menu items are missing. Sure, I see File, Edit, Modify, Create. But some of the items are missing. Noteably "Normals". also there is no preferances menu that can be found to reset preferances. I uninstalled, reinstalled, and tried everything I can think of. IS anyone else having this issue?
Would you mind sending a screen shot? Are you sure your dropdown tab is set to the appropriate type.... ie: polygons
Those drop downs will change what menus appear at the top.
I just thought i would attach a screen shot to clarify..
Please let me know if this resolves your issue. 😃
Paul
If the above posts have resolved this issue, would you mind marking this thread as answered? If you are still having trouble, please do post your current status, i was just checking up on you and saw that no replies were forthcomming so I figure you either solved the issue or nuked your computer 🙂
