Installation & Licensing
Maya 2015 and Maya 2014 open at same time?
8 REPLIES 8
Message 1 of 9
maiahnny
848 Views, 8 Replies
hello
anybody know, how I could open Maya 2015 and 2014 in same time? They are both in Applications and for not beeing overwritten I put the old Mayas in folders.
With Maya 2013 it's no problem to open in same time, but 2014 has lost mr. Surely the path is disturbed. The same, when I put 2015 in a folder, mr can't find the way.
Any ideas, how to use 2014 and 2015 in same time?
Thank you.Smiley Happy
8 REPLIES 8
Message 2 of 9
tony.su
in reply to: maiahnny
Your question confused meSmiley Surprised
If you want launch maya2014 and maya2015, you should click Maya 2014 and then click 2015.Screen Shot.jpg
Tony Su
Product Support
Message 3 of 9
maiahnny
Thanks a lot Tony for your reply.Smiley Happy
As you show with your picture I did too with Maya 14 and Maya 13. But with Maya 15 it doesn't work, as I wote Mr get lost.
In Maya 14 and Maya 15 folder, MentalRay Folder is separat. When I am putting the Mayas in Application folder, I am putting them in an additional folder for they don't  overwrite. The one (in my case Maya 15, which has no additional folder opens with Mr, the other Maya 14 not. I can change this, but at moment didn't find out, how I have to arrange them in Application folder for Mr finds its way. (didn't try with different names, just thriew Maya15 again out for continuing my work.)
Message 4 of 9
tony.su
I don't understand what your mean - mr lost.
I can launch 2014 and 2015 at same time on mac os 10.8.5.
I installed Maya 2014 sp4.
http://knowledge.autodesk.com/support/maya/downloads/caas/downloads/content/autodesk-maya-2014-servi...
and Maya 2015 sp2
http://knowledge.autodesk.com/support/maya/downloads/caas/downloads/content/autodesk-maya-2015-servi...
Tony Su
Product Support
Message 5 of 9
maiahnny
in reply to: tony.su
Surely it's a simple organisation problem.
Opening Maya 2014 and Maya 2015 isn't really the probelm, but when I have put Maya 2014 in an additional folder for not beeing overwritten, I can't find MentalRay under Window/Settings-Preferences/Plug-in Manager.
I discovered, when I wanted to open an old scene with MentalRay in Maya 2014, which was in an additional folder: Script Editor says
// Warning: file: /Applications/autodesk14/Autodesk/maya2014/Maya.app/Contents/scripts/others/supportRenderers.mel line 78: The renderer "mentalRay" used by this scene, is not currently available. The Maya Software renderer will be used instead. //
 So my question should be, how did you organize your Mayafolders in Applicationfolder for they don't get overwritten. Smiley Embarassed
Message 6 of 9
tony.su
My suggestion is - after installed autodesk software, organize the launchpad. It'll easyer.
Tony Su
Product Support
Message 7 of 9
maiahnny
Thanks a lot Tony Su. Smiley Happy I will try this solution, didn't before.
Is what I can see on your picture "organizing launchpad"? Sorry, my Englisch is bad. And "Adim" and "Synergy" are for both version exactly the same?
Message 8 of 9
tony.su
After you install maya 2014 and 2015, there are 8 folders in Autodesk folder, include maya2014, maya2015, mentalrayformaya2014 and mentalrayformaya2015 .
I don't understand why you want to change those folders name.
BTW, this is Launchpad. you can use it to launch your software.
Tony Su
Product Support
Message 9 of 9
maiahnny
It works! Wonderful! Thank you Tony Su.
For AdIm and Synergy are overwritten, I didn't think to this solution. Yes, if that doesn't matter, it's the simpliest thing to install new Mayas.
I am new on MountainLion (had SnowLeopard before), didn't have the time to inspect these new programs, sorry.
Maia
Administrator Productivity
