I uninstalled Maya 2014 and installed 2015 yesterday; however, I failed to uninstall the bonus tools for 2014 before removing Maya 2014... and now I am unable to uninstall the tools as I get an error message saying...
"Autodesk Maya 2014 Bonus Tools requires that Autodesk Maya 2014 be installed on your system prior to installation"
well, yes.. kinda obvious... but i'm actually trying to "un-install" them.
is there a work-around for this?
Solved by tony.su. Go to Solution.
You can try to use microsoft fix-it tools.
http://support.microsoft.com/fixit/
It is a good tools. But I'm not sure if it work in this situation.
You can try to remove the bonus tool script file from
Documents\maya\scripts.
Because by doing this, i have removed mine also.
