I discovered the Service Packs 1-4 for Maya 2014 and I’ve only got some questions regarding the packs after installation:
1. Is it correct, that the new complete size of disc space of Maya 2014 after installation now is 4.5 GB approximately?
2. Service Pack 1 – when I opened/started the file, I noticed, that the file was INSTALLING files – so I’ve chosen as the target folder ..\program files\Maya2014 – is that correct?
Is this also correct for the files mental_ray_Satellite_3_11_1_for_Autodesk_2014_English_Win_64bit
and
mental_ray_Standalone_3_11_1_for_Autodesk_2014_English_Win_64bit
3. Service Packs 2-4 – this packages first EXTRACTED files in one certain folder I’ve given, and from that they automatically run the installation routine, is that correct?
Many thanks to all answers!!!!
Best regards here from Berlin
André
Solved by DarrenP. Go to Solution.
from the Maya 2014 Service Pack 4 read me
• This service pack is a full product installation on all operating systems.
Uninstall your existing Maya application before installing this release.
This service pack includes all of the fixes from releases that preceded it.
Therefore, you do not need to download and install all of the releases in
addition to this service pack. For information on previous releases, see: www.autodesk.com/maya-releasenotes.
you can't install all 4 service packs on 1 machine you can only install 1 of them
i can't speak about the mental ray installs
DarrenP
