Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Maya preferences not written in custom folder...
8 REPLIES 8
Message 1 of 9
FalconCrest
996 Views, 8 Replies
Hi, I have set my preferences file to be written to a different folder within the Maya.env other then Maya default folder, I don't see any files in this custom folder ?
8 REPLIES 8
Message 2 of 9
tony.su
in reply to: FalconCrest
hi,
You can try File path variables - MAYA_APP_DIR from the operating system.
Here is more ditails in Maya help.
http://download.autodesk.com/global/docs/maya2013/en_us/index.html?url=files/Environment_Variables.h...
MAYA_APP_DIR
This variable defines your personal Maya application directory. This directory contains your projects and other important items:
the prefs directory
the projects directory
mayaRenderLog.txt
mayaLog
mayaJournal
the scripts directory
Maya.env, if you choose to create it, can also reside in this directory
You can only set MAYA_APP_DIR from the operating system; you cannot use Maya.env. If you set this variable in the Mac OS X operating system, you must launch Maya from the Terminal window. Otherwise, Maya will not use the set value.
If you do not set the MAYA_APP_DIR variable, the default values are:
Windows XP
\Documents and Settings\<username>\My Documents\maya
Windows Vista and Windows 7
\Users\<username>\Documents\maya
Mac OS X
~<username>/Library/Preferences/Autodesk/maya
Linux (64-bit)
~<username>/maya
Tony Su
Product Support
Message 3 of 9
FalconCrest
in reply to: tony.su
I'm ruling out a plug-in issue !
Message 4 of 9
tony.su
I don't understand your problem.
Maya preferences is stored in prefs folder.
\Users\<username>\Documents\maya\prefs\userPrefs.mel
Mac OS X
~<username>/Library/Preferences/Autodesk/maya/prefs/userPrefs.mel
Linux (64-bit)
~<username>/maya/prefs/userPrefs.mel
Which environment variables you set in Maya.env to change this folder?
Tony Su
Product Support
Message 5 of 9
FalconCrest
I set a environment variable for preferences and plugins.
Message 6 of 9
tony.su
Which one? I mean which environment variable
Tony Su
Product Support
Message 7 of 9
FalconCrest
MAYA_APP_DIR < I don't have set
MAYA_PLUG_IN_PATH < I have set
Message 8 of 9
tony.su
You question is "Maya preferences not written in custom folder".
Set MAYA_PLUG_IN_PATH couldn't change prefs folder. So you couldn't find your preferences setting file in your customer's folder.
Tony Su
Product Support
Message 9 of 9
FalconCrest
It was removed from a 3rd party plugin.
