I'm trying to go 100% portable with my work and was hearing good things about the Wacom Cintiq Companion. It uses Windows 8 and you can sketch in Photoshop just like with a regular Cintiq but it's small like a tablet. My big hesitation is that I need to be able to work in Maya 2014. Anyone have any experience trying to do that?
FYI here are the specs on the CC:
I'm not able to 100% answer your question here but I will offer the information I have.
While Maya may run on the it, Autodesk does not certified/qualify the Cintiq Companion to run with Maya.
Basically it will probably run Maya, but its not the best choice to do so.
If there are other users on the forums that use Maya on Multi-Touch devices they may be able to offer more input but personally I wouldn't recommend it as your main Maya solution.
Thank-you.
Karen
The companion is not my main computer, but I use it alot for some heavy modeling and i'm ok with the performance. I use the companion mostly for sculpting but I find myself always using it for Maya as well.
