In the file attached,
When you selects multiple faces on the one side of the wing, the faces on the other side of the wing will not get selected.
I would like to have the feature that when I select the front faces, the faces behind the selections also get selected so that I can delete a whole side of an object easily, but there seems to be no way to get that feature back.
Unchecking backside curling does not seem to work.
Please help me.
Thanks.
This problem is the same as the other one you posted - you have the "Backface Culling" set in the attribute editor to "full". Turn it off and you will be able to select the faces in the back.
