If you are tracking a moving object (head) and the camera moves too, then I think you need a more than one camera to get a solve for both the camera movement in the scene and the motion capture of the head. The witness cameras (not sure if you need two or just one) need to be still.
I'm not entirly sure because I have never go this to work myself. I have only managed to do a head track with a single locked on camera. And I didn't do that by the conventional method, I tracked it as if it were a moving camera, then at export told it to keep the camera still and move the scene.
There are some tips and shots to practice with here.
The Blaster Walk clip uses just one moving camera and a survey shot of the object, but the object is a rigid, non-deforming object.
In the Body Capture shot, there is a moving camera and two locked witness cams, because the body is not rigid.
The thing is, I never did get the motion capture to work as it should in MM, only on the tutorial that comes with the program.
