Funny thing, mm does not really crash, it just is extreeeeemly slow. When you leave mm staring up for an hour, you get the interface but still can not work in it because it is incredibly slow.
ADSK Support said that I should try to turn off my network connections, meaning
plugging the cables off and shutting wireless down...bang it works...
BUT
when matchmover is running you cannot just plug your network back in, mm instantly gets into slow motion mode again and does not respond until you plug your network out.
As it seems there is no known solution to this problem, ADSK support has no fix for this.
Bottom line is, forget about network drives or internet connections while working with mm 2011, then it works.
This is one of the strangest problems I ever encountered, I think it has to do with some weird licensing error that tries to scan the network or so. I hope for a fix soon since this is really annoying 😉
Win 7 Ultimate, 64bit, Geforce FX m2700, matchmover 2011 for 3DS Max 2011
Hope this helps some of you guys.
Ciao,
Dan
