This post is copied from Autodesk LAB Forum (Original Date: 06/27/2014)
I have floor and room schedules, but the LEED floor schedule is not being generated. It appears but has no values under the column headers. Also for the room schedule I have rooms defined and I can select which to include in the daylight analysis, but for the "% within threshold" column all the rooms give the result "-1". Any suggestions on why this may be happening?
Solved by Mohammad_Asl. Go to Solution.
Thanks for the screenshot that makes it easy. It looks like your ’include in daylighting’ parameter is not initiated (it’s greyed out). Click on that until you get a black check mark and it should regenerate results correctly.
Can you tell me what you did to get grey parameters? Is your model one you ran previously with an older labs release? Are you using 2014 or 2015. We changed the schedule name so we may have to also reinitiate the parameters automatically to make it easier for you.
Thanks!
Clicking on them worked! Now that I’ve updated to the production version for 2014 I don’t have that problem anymore.
Thank you!
