Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
looking for some tutorials / output & size issues...
2 REPLIES 2
ianmacleanllc
466 Views, 2 Replies
loving the software, but having some issues with the output.
setting up the screen sizes and what type of output seems to be a bit fuzzy. when you are making something for print (say word template) should this same publisher file work well for mobile divice output without much fussing with the file?  i seem to be not grasping this part... just when i think i get something looking good i then push it out to mobile and things look nothing like the screen or print version.
thanks
-ian
2 REPLIES 2
peggy.wang
in reply to: ianmacleanllc
Hello Ian,
Thank you for the feedback.
Please try to edit the PPI in right of the publish area
change the PPI to 300 , it will looks better when publish to word and image.
refer to attched image.
Peggy
--Autodesk Inventor Publisher QA
Peggy Wang
Sr. Software QA Engineer
Publisher Quality Assurance Team
Autodesk, Inc.
Hi Ian -
Different outputs require different setup values, so that is most likely why you are experiencing some inconsistencies when exporting a presentation set up for Print to Mobile.
It's a good idea to set up a seperate storyboard for each output format. After the presentation has been completed, simply copy/paste the Storyboard to create an identical copy to manipulate. See screenshot below for a sample.
<see attachment: storyboards.png>
Inside the Mobile storyboard, you can quickly set the Publish Area appropriately using the "set affected snapshots" command. Right-click on any snapshot within the Mobile storyboard and select Set Affected Snapshots for All Snapshots within the Storyboard.
<see attachment: set affected snapshots.png>
With the snapshots activated, modify the Publish Area to the appropriate iPad settings (1024x768).
<see attachment: publish area.png>
This will automatically update the Publish Area of every snapshot within the storyboard to these settings. At this point, it's a good idea to take a pass through the snapshots and ensure the views are within the boundaries.
You're now ready to publish to Mobile with much higher fidelity than before.
Good Luck!
Timera Hart
