Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
iOS5 problem
9 REPLIES 9
Message 1 of 10
441 Views, 9 Replies
iOS5 problem
Content is listed on the left hand side of the viewer but when clicked, nothing happens.
9 REPLIES 9
Message 2 of 10
rajkumar.ilanchelian
Hello Jeff,
I assume you are seeing this on the iPad? If so can you please specify if it is the iPad or the iPad2?
-Raj (Autodesk)
Message 3 of 10
in reply to: rajkumar.ilanchelian
Yes.  I am running iOS5 on an iPad 2.  An associate is also having the same issue with the same content on an iPad 1.  I also run iOS5 on an iPod Touch but the content works there.
I'm currently trying to delete and re-add the content on the iPad2.
Message 4 of 10
Thanks for the information. We will look in to this issue.
-Raj (Autodesk)
Message 5 of 10
Jeff,
From my limited testing I notice that the "sample content" files found in the models tab is the ones that are not showing up. Files that I have published to the Autodesk server is displaying correctly. Is this true in your case as well? Are you able to view the files that you have published to mobile?
-Raj (Autodesk)
Message 6 of 10
I don't have anything published to the server.  I can view the models in the "Gallery" but not the models I add through iTunes into the app's "Models" fiolder.
I tried deleting the models from the iPad and re-add them through iTunes and then sync.  This results in nothing showing up in the app "Models" folder.  I even restarted the app each time I tried something new.  Meaning I double click the home button and remove the app from memory.  I also tried a soft reset on the iPad 2.
As it sits now, I have no content loading to the app even though iTunes shows the content in the Add window.  I can view the Gallery models.  I have no published content but will try that next.
One last thing, I've been syncing tethered to a Macbook Pro.  Not using the wireless sync.
Message 7 of 10
Thanks again for the details. I take it that this was working for you prior to iOS 5 updates correct?
-Raj (Autodesk)
Message 8 of 10
Yes.  Everything worked before but now the iPad 1 and 2 do not work.  iPod touch still works even with iOS5.
Message 9 of 10
New iPhone4S running iOS5 works.
Message 10 of 10
Got it working on the iPad2.
Here's how I did it...
On the iPad, deleted the app from the iPad.
On the iPad, went to the Appstore and re-downloaded IPM Viewer
In iTunes, added my models
In iTunes, did a Sync.
Models show up as before.
