Inventor Publisher
Welcome to Autodeskā€™s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Showing results forĀ
Did you mean:Ā
Zoom Settings
3 REPLIES 3
VictorBDEngineer
987 Views, 3 Replies
Zoom Settings
Why does publisher not maintain the current zoom level when changing views? It most inconvenient having to zoom back in after changing a view. Is there anyway to maintain the zoom level?
Regards
Victor Pringle
3 REPLIES 3
dmjessup
in reply to: VictorBDEngineer
Simple fix for you. Right-click on the cube in the upper right-hand corner. Select properties. Uncheck  Fit to view on view change. OK and you're done.
VictorBDEngineer
in reply to: dmjessup
Thank you.
I had not been aware of that.
Regards
Victor Pringle
kondziorf
I changed this and it works when using cube, but what about when I have views under keys 1, 2, 3 shortcuts? They apply fit to view and I don't want it. Can I change it there too?
P.S Its for Inventor not Publisher, didn't see that, but maybe fix will be the same for both
