Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Will not import from Vault
5 REPLIES 5
bowen192
906 Views, 5 Replies
I get the following message wheen trying to import from Vault:
Failed to complete the vault command 'Insert From Vault'. - The process can not access the file, because it is being used by another process.
I am the only person using Publisher, but the file is almost constantly used by someone in Inventor.
How can I fix this?
5 REPLIES 5
bowen192
in reply to: bowen192
I'm quite keen on speaking to someone from Autodesk about this, as I'm currently at a work stop.
bowen192
Now my projects have stopped opening:
bowen192
Sorry to interupt the Autodesk Christmas party, but I am still having problems.
I can now import a file from Vault and save in to Vault.  However, I cannot open it and get the following:
bowen192
Alright, alright.
I don't even want an answer any more, just a response, anything just to aknowledge Autodesk recognise there may be a problem.
Cheers.
LeoWan
Hi ,
would you please try insert this inventor file from local folder?  we will then investigate what is the issue.
publisher has a local folder mapped to vault folder, when insert from vault, it will download files to local folder.
Leo
