Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Visibility issues
5 REPLIES 5
kwilson_design
745 Views, 5 Replies
Visibility issues
Not sure why I'm experiencing this issue and curious if anyone else can replicate.
I have a publisher file I'm working on. One of the components or parts I have turned off the visibility so it won't show up in the animation sequences. However once I publish to mobile and the file becomes available on A360 I notice the part I turned the visibility off on my desktop has now mysteriously turned back on and is visible online.
anyone else have this issue? How do I prevent this from happening?
Kenny
If this post solved your issue please mark "Accept as Solution". It helps everyone...really!
5 REPLIES 5
irene.chen
in reply to: kwilson_design
HI,
Thanks for your feedback. I can't reproduce this issue at my side, could you please provide more detail information about this?
- Are you using Inventor Publisher SP2 for publishing?
- Are all invisible components visible after publisher to mobile and view in A360 or IPMV?
- Which file type you inserted?
Do you mind sharing the files to us?
Irene Chen
Publisher QA
kwilson_design
in reply to: irene.chen
  • Yes I'm using Publisher 2013 SP2.
  • Not every invisible file is behaving this way. It seems just one file in perticular.
  • These are native Inventor files imported into Publisher.
Kenny
irene.chen
How did you change the visibity status? it is invisibled in Inventor or in Publisher directly?
Irene Chen
Inventor Publisher QA
kwilson_design
I am changing visibility within Publisher.
The strange thing is that I can change visibilty of other components (within Publisher) and they remain hidden or invisible. Even the component in question remains invisible.
It is not UNTIL it's published up to the A360 site where things get messed up and components become visible that in the software were made to be hidden or invisible.
Kenny
irene.chen
Could you please share the iam file and ipb file to us?
Irene Chen
