Inventor Publisher
Valued Contributor
michael.shelley
Message 1 of 5 (196 Views)
Styles Issue
196 Views, 4 Replies
03-31-2011 11:05 AM
Guys,
I am in the middle of a very fustrating problem. I have set up a publisher document with many snap shots showing various views and details. I had set up each view with slightly differt styles. (technical line drawing, ghost, shaded, gray scale etc..).
Now I can't change the styles back to what I had originally. I have tried everything. Can anyone help me on this?
Thank you in advance!!
Michael
Board Manager
Jon.Balgley
Message 2 of 5 (191 Views)
Re: Styles Issue
03-31-2011 05:01 PM in reply to: michael.shelley
Try this:
  • Select the root (or highest level assembly of interest) in the browser on the left.
  • In the styles command (gallery) select "Clear Style"
That may work.  If it doesn't work, try:
  • area-selecting all the components (drag-rectangle-select)
  • Then do Clear Style
If that doesn't work then try to select all intervening sub-assemblies (one at a time, for a start), and do Clear Style on them.
Let us know if any of those work.  Sorry it's not easy.
Jon Balgley
Autodesk Configurator 360 / Inventor ETO team
Valued Contributor
michael.shelley
Message 3 of 5 (184 Views)
Re: Styles Issue
04-01-2011 12:35 AM in reply to: Jon.Balgley
Tried all of these things. And nothing!! It now looks like I have to make a new publisher document. Now I'm a little afraid of using styles. Unless you can suggest something else?
Using publisher 2012 by the way.
Michael
Board Manager
Jon.Balgley
Message 4 of 5 (176 Views)
Re: Styles Issue
04-01-2011 11:55 AM in reply to: michael.shelley
Can you send me the IPB file?  Or a representative sample?
Email to jon.balgley@autodesk.com
Thanks, and we'll try to help!
Jon Balgley
bowen192
Message 5 of 5 (166 Views)
Re: Styles Issue
04-04-2011 01:37 AM in reply to: michael.shelley
I don't know if this helps but I had a simalar problem and found a workaround.
I found that I could not change the style of a complete assembly if I'd already done it once already.
My workaround is to select a single component, invert the selection and then change to the desired style.  Select the original single component and change that to the desired style.
Hope this makes sense.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
