I found the time this day to write down only a few hopes for 2014 and misses for 2013
So i think this is enough for this first list.
I hope my thoughts will help you
Hi Frank,
Thanks for your feedback. I have add these wishlist to your internal issue tracking system.
-Irene Chen
Inventor Publisher QA
Hello Irene
thank's for your feedback.
You and the dev team can contact me when ever you like to get more detialled thoughts.
It will be interesting what the dev team says about my ideas.
To far away from real or a understandable customer enhancement 🙂
Thank you! Frank
These suggestion are helpful for us to know what the real user want. I've add these as wishlist and give PD for referencence.
-Irene Chen (Irene.chen@autodesk.com)
I miss some better way to align callouts, like a grid or something!
I also would like to separete the Move and Restre Home button. i would also like to be able to insert other type of document in Publisher like word documet or PDF and be able to choose if the snapshot will be visible in the published document.
just my wish list.
Best regards
Timmy
one more!
be able to search and replace text in the publisher file.
maybe even some spelling correction.
Hi Timmy,
Thanks for your suggestion, I've added it to wishlist in the internal tracking system.
Irene Chen
Nice to hear!
I would also like to be able to control the visible trails like i can do in a Inventor presentation.
I have the same problem with trails here. I would like to make a part of a trail line invisile. See image.
I think there is no way to do this in Publisher 2013
one more thing:
text justification (Left, Center and Right) when creating a label.
by the way when will inventor publisher 2014 be released?
Best regards
When you select the Move function, it appears at the centre of the selected object.
This is frustrating when zoomed in to something that you simply want to move along an axis.
Have the ability to snap the Move function into view.
As we are in ideas here, there should be a way to improve the update functions, specially when parts are moved or exploded and the original parts have modifications. It's all explained here : http://forums.autodesk.com/t5/Autodesk-Inventor-Publisher/Update-causes-components-to-move/td-p/3882...
Maybe I missed something on the way to use Publisher but if not, this behavior makes it impossible to really use it.
@aguitton116 wrote:As we are in ideas here, there should be a way to improve the update functions, specially when parts are moved or exploded and the original parts have modifications. It's all explained here : http://forums.autodesk.com/t5/Autodesk-Inventor-Publisher/Update-causes-components-to-move/td-p/3882...
This is a problem with Publisher. It used to update fine, but it has never worked in 2013 for me.
