@fsanchou wrote:I have two questions:1) How change the gray color of the cut plane?
2) There is an error line when I publish to Vector a snapshot with a section plan. How would you do that?
1) You can change this by altering the Hatching Style.
Right click the object and selct Hatching.
You should get this menu:
You can change the pattern, colour and all that good stuff here. Any problems, type hatching in to the help file; there are some pretty good videos in there.
2) Not sure about this, not sure Autodesk do either: http://forums.autodesk.com/t5/Autodesk-Inventor-Publisher/Visualization-issues-in-Inventor-Publisher....
Oh dear, my answer was nothing like what you requested, was it? I don't think what you are asking is possible, sorry. I'm sure it'll be in SP3 - Mega Update though.
@fsanchou wrote:Thank you for your reply but I do not want to change the color lines. I want to change the background color when I'm use technical drawing (see image2.jpeg)
I did not feel that this is possible.
Regarding the problem of visualization, I do have the same problems that visualization in the subject you mention. But my problem here concerns the publication in vector format. Publisher publishes poorly a snapshot that contains a section plane.
