Inventor Publisher
Active Contributor
timmy.stalnacke
Message 1 of 19 (508 Views)
Renaming parts. problem with updating.
508 Views, 18 Replies
04-04-2013 04:01 AM
Our company have changed our part number system (added a dot).
When I update the ipb file some parts lose their position and visibility.
And also the trail disappears, even that "trail visibility" is ticked. But if I unticked it and ticked it again, the trail is visible again.
This is pretty annoying and I don't want to restart from scratch every time the assembly is being updated.
Best regards
Active Contributor
timmy.stalnacke
Message 2 of 19 (504 Views)
Re: Renaming parts. problem with updating.
04-04-2013 04:37 AM in reply to: timmy.stalnacke
the problem seems to be that i cant "Update All Components"
i got a box that says "Some update paths are not valid. Press OK to continue update".
when i press OK, nothing happens.
What doses "some update paths are not valid" means?
i have open up the assembly in Inventor and update and save it, even checked it in vault.
bowen192
Message 3 of 19 (495 Views)
04-04-2013 05:54 AM in reply to: timmy.stalnacke
I've had a similar-ish problem.
I'm not sure this is of any use, but if the component is linked to Vault you can right-click it and chose Recover From Vault.
This has fixed things for me in the past.
Active Contributor
timmy.stalnacke
Message 4 of 19 (492 Views)
04-04-2013 06:19 AM in reply to: bowen192
Thanks, but i have already tried that, when try to recover from vault some of the parts loses the placement and visibility state.
If i look the browser i can see that some parts are market with a red cross and some with a pen, and in the end some parts have some kind of star, i guess that the star means its new parts?
but they are no new parts at all. just renamed parts.
Best regards
Employee
LeoWan
Message 5 of 19 (477 Views)
04-10-2013 10:37 PM in reply to: timmy.stalnacke
Hi Timmy,
 I guess you also renamed the assembly file ? if so, please try below steps:
1. choose the top assembly file that you want to change in Publisher browser, right click to invoke context menu, choose "Source Files>Replace from local files",
2. pick up the renamed assemly file
3. do update
Leo
Active Contributor
timmy.stalnacke
Message 6 of 19 (475 Views)
04-10-2013 10:41 PM in reply to: LeoWan
Hi!
Thanks for the response.
Yes we also have renamed the assembly file. but the main problem is that some of the parts loose its positions and visibility state.
Best regards
Employee
LeoWan
Message 7 of 19 (466 Views)
04-10-2013 10:52 PM in reply to: timmy.stalnacke
Publisher won't take the renamed assembly as the same one with previous file.  That's why update don't do anything. After you recover file from vault and do update, it is processed by the old assembly file and renamed part files. this is not what you expected.
Please try my previous steps and see if it resolve your problem.
Leo
Active Contributor
timmy.stalnacke
Message 8 of 19 (445 Views)
04-15-2013 01:43 AM in reply to: LeoWan
Hi!
that exactly what i have done (your previous steps) that when the whole model mess up.
Employee
LeoWan
Message 9 of 19 (435 Views)
04-15-2013 06:30 PM in reply to: timmy.stalnacke
Hi Timmy,
Would you mind provide your files both of the inventor files and ipb files before and after renamed for us to investigate?
Leo
Active Contributor
timmy.stalnacke
Message 10 of 19 (427 Views)
04-18-2013 12:35 AM in reply to: LeoWan
Yes i can !
please send me a upload link!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
