Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Publisher Browser Icon????
4 REPLIES 4
stevenguy
741 Views, 4 Replies
I still using IP 2011 R1 and I never see these icon before.
Can any one tell me what those icon mean and how to clear them.
See the attached picture
Steve Nguyen
CAD Admin/ Eng
Inventor Pro, Inventor Publisher & Vault 2016
Intel(R) Xeon(R) CPU X5690 @3.47GHz (2 processors)
Mem 48.0 GB
OS Win 8.1 64-bit
Graphic Card: Quadro FX 4800
4 REPLIES 4
Steve,
Did you do a update to the Inventor assembly that you inserted in to Publisher? This is an icon that tells you which components were updated/deleted. These should how ever go away on ipb save. Do you still see them after a save?
-Raj (Autodesk)
I did many time and the update go thru ok.
I think the icon that has the X infront that is the file that I deleted from Inventor.
The file icon has the pen infornt I think it need update and I try update the file many time but it not go away.
the other icon has * infront I am not sure what is it yet.
P.s I think if I use the IP 2012 then I can replace the file with another file then this issue may go away.
IP 2012 has the feature to replace the existing file with another file from another location.
This replace feature is good and it work better than update.
Steve Nguyen
CAD Admin/ Eng
Mem 48.0 GB
OS Win 8.1 64-bit
Steve,
You are right. The files that have the X means that the file has been deleted. The other icon means that this particular component has been changed. The * icon means these components did not go through any change.  All these icons are temporary after an Inventor update. They should go away once you save the IPB file. Do they?
-Raj (Autodesk)
After I hit save the file then all icon back to normal and the deleted file with an X all gone and the IP file look the same as the Inventor .iam
Thanks for helping
Steve Nguyen
CAD Admin/ Eng
Mem 48.0 GB
OS Win 8.1 64-bit
