I've just installed Publisher 2013 running a dual monitor setup (Nvidia Geforce GTS450 with 296.10 driver) and for some strange reason the ribbon appears on the 2nd monitor, while the application is running on the 1st monitor. Does anyone know how to rectify this please?
My current workaround simply involves dragging each part of the ribbon back onto the 1st monitor so that it is no longer parked in the normal position.
Thanks in advance
Ben
Hello Ben,
Right click on the ribbon and select reset ribbon. Does this solve your issue?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Hi Rajkumar,
Unfortunately not. I tried it and it just sets it back to the 2nd monitor.
Regards
Ben
I am having this problem too.
@Anonymous wrote:Hi,
Thanks in advance
Ben
Thank you both for letting us know of this issue. We are working to resolve it in a timely manner.
Thank you,
Timera
I just installed Publisher 2013 and I am also having this problem. I found a work around that works pretty well. Don't maximize the program window on the monitor 1. Instead, simply stretch the program out so that it mostly covers the whole monitor 1. The ribbon tends to stay in the proper place when it is not maximized.
Daniel Hermanson
Spraying Systems Co.
Any update on this? I have several clients with this issue. With a great number of Inventor users using a dual monitor setup, here's to hoping a fix is seriously being looked into.
Hi Ben,
Thanks for your post. Yes, we are *actually* working on a solution for this, rest assured. In the meantime, the simple workaround that Daniel provided in this thread works well. Simply refrain from maximizing the Publisher window in the 2nd monitor, and stretch the window to meet your monitor size instead. This keeps the ribbon and all of it's components in place.
Happy Publishing,
Timera
Hi All,
This is one of the fixes that are a part of the Service Pack 2 that we announced yesterday. Be sure to download it here to experience all of the benefits.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20162424&linkID=14856948
Happy Publishing,
Timera
Hi Timera,
Many thanks for keeping us updated throughout. I will get the service pack loaded and get to work!
Kind regards
Ben
