Inventor Publisher
Board Manager
Message 11 of 20 (750 Views)
Re: Publisher 2012 Service Pack 2 is now available
09-02-2011 10:49 AM in reply to: bowen192
Backup files should be saved under the "OldVersions" folder, in the same location as the original IPB file.  If they are not being saved there, please let us know.
If you want to uninstall SP2, you need to go to the Windows "Add/Remove Programs" (aka "Uninstall Programs") window (this is slightly different in each version of Windows), and then select the "View Installed Updates" option.  The updates for each program are listed there.  This will allow you to uninstall SP2 and go back to SP1.  If you decide to go this route, I hope that you will report back on what happens.
Jon Balgley
Autodesk Configurator 360 / Inventor ETO team
Autodesk, Inc.
bowen192
Message 12 of 20 (743 Views)
09-05-2011 03:11 AM in reply to: Jon.Balgley
Uninstalled SP2.
Seems to work a bit better.
Only crashed twice this morning, once when changing a component style, and once when selecting a custom selection.
No backup (as I'm not on SP now) but I've only lost an hours work this morning which is pretty good.
EDIT: Just noticed that, despite saving it almost every ten minutes, it hasn't saved my work once today.  So I'm actually back to where I was at 0830 this morning.
*Expert Elite*
Mark_Wigan
Message 13 of 20 (621 Views)
02-22-2012 07:34 PM in reply to: bowen192
hi bowen192, i am just wondering did that sp2 ever get sorted? it seemed pretty bad from what i saw.
i use inventor but we just got publisher 2012 for our guys to do manuals with, but i jumped on myself & had a bit of a go to see how it performed, then after i found some issues, downloaded and installed sp1 & sp2 just now and by doing so completey lost the ability to manually explode.
i had a look for a hot fix and found none... just the sp1 & 2 that i had already scored.
after reading a few threads on here i uninstalled sp2. considering this was released several months ago i am wondering if i am missing something. Autodesk usually takes a while to fixing their software but i am surprised they seem to be ignoring this.
besides that. i am looking for a way to make templates, export to pdf without proportions of image distorting and a few other things that do not seem to work or allow users to configure options to control it.
best regards,
- Mark
PDSU 2014 Windows 7, 64bit. (please consider Kudos or Tag as Solved if your issue is sorted)
bowen192
Message 14 of 20 (615 Views)
02-23-2012 02:10 AM in reply to: Mark_Wigan
I've just read back all my posts; my, my, I'm an angry young man.
Short answer
It is better, but there are lots of frustrating crashes still and performance is a major issue.
Long answer
From what I've seen and read on here over the last few months, it seems Publisher's main issue is dealing with lots of components.  If you look at any complaints on here, they are always from people with large amounts of components in their models.  If you have less than 100 components, it seems to be fine.
Application errors I still have include;
Applying styles; if you change Styles on sub-components, changing a style for the whole assembly does not work.
Setting affected snapshots; changing styles and backgrounds over multiple snapshots often doesn't work.
Crashes at least twice a day.  Wouldn't be so bad if it ever saved a backup file or if saving large models didn't take so long.
I could go on all day.  Autodesk do seem to be responding and interacting with us now though.  This time last year, it would take a month for them to get back to you.  Now you get a response within a day.  Timera seems particularly enthusiastic.
Employee
TimeraAutodesk
Message 15 of 20 (607 Views)
02-23-2012 02:09 PM in reply to: bowen192
The Backup file will be placed directly into a folder called OldVersions, with SP2 installed are you not seeing this folder being created at all?
Employee
TimeraAutodesk
Message 16 of 20 (605 Views)
02-23-2012 02:16 PM in reply to: bowen192
Hi Guys -
While it's true that very large assemblies bog down performance within Publisher, I think I'm beginning to understand where some of these crashing and performance issues are coming from. In case you weren't aware, SP2 will only work if you have SP1 completely unistalled first. I apologize if that wasn't made clear before.
Do me a favor and uninstall both SP1 and SP2 from your drives, restart your machine and then install ONLY SP2.
Then let me know if you see a difference :smileyhappy:
Timera Hart
*Expert Elite*
Mark_Wigan
Message 17 of 20 (590 Views)
02-24-2012 06:00 PM in reply to: Jon.Balgley
thanks bowen192. knowing that will save me time trying to figure out if i was missing something or if it was just the software.
Timera, i appreciate that reply. that explains a lot... i had installed sp1 and then sp2 (which from my experience that requirement is typical for the family of autodesk products i have been using) so i am surprised to hear that sp1 had to be uninstalled prior to sp2. (i had read through the help "readme" files to see if there were any notes on this and saw none. you should make sure that kind of thing is very clear on the download page for those kind of updates and service packs). is it too low brow of me to suggest that Autodesk please consider your customers time is vaulable and maybe  some testing at your end before you sell software or roll out updates without including important information.
best regards,
- Mark
bowen192
Message 18 of 20 (581 Views)
02-27-2012 04:03 AM in reply to: TimeraAutodesk
It's there, but the documents are just a history of user saves, which I fail to see a use for.
There never appears to be a crash file.
Valued Contributor
smilinger
Message 19 of 20 (474 Views)
12-04-2012 11:12 PM in reply to: Jon.Balgley
Do I need to install SP1 first then SP2? I see no instruction about this in the readme.
bowen192
Message 20 of 20 (469 Views)
12-05-2012 12:48 AM in reply to: smilinger
No, do not install SP1.  Just install SP2.
Can't believe it's not in the readme!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
