Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Product Key for Publisher 2013 R1?
9 REPLIES 9
Message 1 of 10
mthomas
8360 Views, 9 Replies
Attempting to install Inventor Publisher 2013 R1 and it will NOT accept the Product Key from Publisher 2013... what Product Key are we supposed to use?
Mike
Mike Thomas
9 REPLIES 9
Message 2 of 10
philip.s
in reply to: mthomas
Hi Mike,
I just responded to your tweet as well, but the correct product key for Inventor Publisher 2013 should be 666E1. A complete list of supported version product keys can be found here.
Are you able to provide a screen shot of the installation screen (removing your licensing info)?
Message 3 of 10
mthomas
in reply to: philip.s
Here it is,... i've restarted the installation a couple times and get the same results each time
Mike Thomas
Message 4 of 10
camilo.lemos
Hi mthomas,
I've just replied to you on Twitter:)
Can you please send me the serial number you are using via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message)?
Thank you
Camilo Lemos
Message 5 of 10
philip.s
Following up on this one, it turns out that Inventor Publisher 2013 R1 has a completely different serial number and product key (666E2) than Inventor Publisher 2013, mirroring the behavior of an upgraded license as apposed to a simple upgrade or service service pack.
In case anyone else finds themselves in this situation and does not have access to the updated serial number, please contact our License Assistance Team for a full license report.
Message 6 of 10
ulasdeniz
Hi, I need to use the inventor publisher trial. But ı could not find it. I tried to use 2013 but it was very problematic even with updates. I also use 2012 inventor so that I need it to try for 3d pdf  creation for my homework. There is no any student version for 2013 R1 publisher. Where can I find its trial version, can you help me?
Ulaş Deniz
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ( "ACCEPT AS SOLUTION" ) seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" (KUDO) ile ödüllendirin.
Youtube : https://www.youtube.com/channel/UCkJpVueGScmJvW1RIgqttSg
Message 7 of 10
philip.s
in reply to: ulasdeniz
Hello Ulas!
We are actually in the process of adding Inventor Publisher 2013 R1 to the Education Community. In the mean time, you can access the software as a trial here: Inventor Publisher 2013 R1
Message 8 of 10
ulasdeniz
Thank you Philip. I downloaded the R1 version of Inv. 2013 and installed it as trial. it is working without any problem and opens the Inv 2014 files. I have Inv. Publisher 2013 Service Packs. Do I need to istall them for Inv Pub. 2013 R1 or it is currently updated? Thanks for your response.
Ulaş Deniz
Message 9 of 10
camilo.lemos
Hi Ulas,
At the moment there is no need to install any service packs or updates to Inventor Publisher 2013 R1. You can keep an eye on this page for future service packs and updates.
Best regards,
Camilo Lemos
Message 10 of 10
info
tfe correct key for publisher 2013R1 is 666E2
