Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Problems with Publisher 2013 R1 and is there an alternative?
28 REPLIES 28
Message 1 of 29
VictorBDEngineer
2239 Views, 28 Replies
Can anyone suggest some tutorials on using Inventor Studio to generate pictures of the build up an assembly like that can be done with Inventor Publisher.
The latest version of Publisher 2013 R1 will not me let me insert a model or for that matter it will not even create an empty file without crashing. Plenty of crash reports but no respone about the problem.
So I am having to resort to looking for alternatives to get my project completed. Publisher 2013 works fine but it can not open Inventor 2014 files.
So I am looking at using Inventor Studio but I have the feeling that it is not up to the job. As far as I can see it just produces animations which is not what I want.
Is there a Publisher alternative out there?
Regards
Victor Pringle
28 REPLIES 28
Message 2 of 29
in reply to: VictorBDEngineer
I'm investigating the option to get a "reprint" of part of a book, the chapter I wrote about Inventor Studio.
The book Mastering Autodesk Inventor 2009 had a chapter (16) in it that was an in depth discussion about Studio with examples.
Should my request get approved, I will let you know how to access the information.
-Bill Bogan
Message 3 of 29
VictorBDEngineer
I have managed to find a copy of "Mastering Autodesk Inventor 2010" and the chapter you suggested.
The problem I have now is trying to map the  Inventor Studio paradigrams to Publishers. Like how do I move a part and get a trail back to its original position? How do I add annotations and call outs with part numbers? In all I do not think Inventor Studio is up to the job but as I can not get Publisher 2013 R1 to work I have little option but to try and use it.
Is there any way of converting Inventor 2014 files back to Inventor 2013 so that I can use Publisher 2013?
Message 4 of 29
You are right; Inventor Studio has limited capability and isn't designed to provide a "Publisher" type experience. It is for rendering images and video animations of products. Its strength is that it allows you to animate components, constraints, parameters, cameras, and lights to produce the output.
I misunderstood your original post, thinking you wanted only to output images of an assembly build up. Which you can do with studio. The video output choices are sequential images or video, so it would be possible to post-process the images to add whatever you want, but it would become tedious as you add the content over numerous frames.
Sorry I couldn't be of more assistance.
Message 5 of 29
I have no problem with Publisher as a program and I think it is a great product.
The issue I have is that Publisher 2013 works fine on my computer but Publisher 2013 R1 does not.
I have moved onto Inventor 2014 which does not work with Publisher 2013. As Publisher 2013 R1 refuses to work I am now screwed and have to look for an alternative.
Is there any way of converting Inventor 2014 files back to Inventor 2013, surely there cant be that much difference between them?
Regards
Victor Pringle
Message 6 of 29
DarrenP
Regards
Victor Pringle
no there is no saving down in inventor you can export as a step file but you lose your feature history
DarrenP
Message 7 of 29
VictorBDEngineer
in reply to: DarrenP
Thank you, you are a life saver.
It had not occured to me to export the model in another format.
I exported my Inventor 2014 assembly into a STEP file and loaded it into Publisher 2013. Everything was there and Publisher 2013 works fine.
So I can still use Inventor 2014 and publish with Publisher 2013.
Publisher 2013 R1 is going into the trash until they come up with a version thats works for me.
Regards
Victor Pringle
Message 8 of 29
Found out it is better to export in DWF format that also gives you a parts list which is not available with the STEP export.
Message 9 of 29
I still can not get Publisher 2013 R1 to work. It crashes without any error reports when I either try to create a new file or try to insert a model into an existing file. Is there any fix for this?
regards
Victor Pringle
Message 10 of 29
Hello Victor,
Thank you for using Publisher and sorry to hear that you are still having problem with Publisher 2013 R1.  Have you tried to uninstall and re-install Publisher 2013 R1 to see if it works? Also, could you please let us know your detailed machine and OS specifications? Thank you!
-Huan
Inventor Publisher Team
Message 11 of 29
Yes I have tried uninstalling and reinstalling.
My system configuration is attached.
Regards
Victor
Message 12 of 29
training
Hi, when i first tried publisher it was the trial of 2013, and it was about the most crashy application i have ever used.
It had all the unreliability, crashed every 10 minutes and was not production ready.
Based on its reliability Autodesk were lucky to have sold another copy of it.
When we came to actually buying and using it we were taking no chances, so we started with a clean new PC and installed everything we use on it including Publisher 2013 R1 and its been not too bad since. Apart from all the other issues on this forum!
Steve
Steven Dewar | STATS Group | 3D Animator
Win7Ent-64-SP1 | 32GB | Intel Core i7-4770CPU@3.40GHz | Quadro 4000 GPU
Message 13 of 29
Thanks for the quick reply, Victor.
Please allow me to check a few other things:
1. Have you installed the service pack for Publisher 2013 R1? We addressed a problem in Win 8.1 for Publisher 2013 R1.
http://knowledge.autodesk.com/support/inventor-publisher/downloads/caas/downloads/content/autodesk-i...
2. Is this the only computer that you have problem using Publisher 2013 R1? Have you tried on other machines?
3. You also have Publisher 2013 installed on this notebook, right? Any other Autodesk products you have installed?
Thank you for more info.
-Huan Yu
Message 14 of 29
Applying the service pack made no difference.
I did have Publisher 2013 installed but I had a hard disk crash and I have not reinstall it.
I also have Inventor Professional 2015, 3ds Max 2015 and AutoCad 2015 installed although I dont use AutoCad.
Regards
Victor
Message 15 of 29
na.miao
Hi Victor,
   does publisher crash when you insert any files or just some file(inventor? solidworks?DWF?)
   Is your win8.1 installed directly or updated from win8? and did you uninstall and re-install in win8.1 OS?
   thank you
Na Miao(Autodesk)
Inventor Publisher QA
Message 16 of 29
VictorBDEngineer
in reply to: na.miao
Publisher 2013 R1 crashes when I try to create a file and when I try to insert a model in an existing file.
My win8.1 was an update of win8. I had had a hard disk crash and  I have been re installing all my software after upgrading to win8.1
I have just reinstalled Publisher 2013 and that is now not even starting.
Regards
Victor
Message 17 of 29
I would suggest a deep-uninstall of previous versions using Revo Uninstaller (free version available). Then, try re-downloading the software and install - if you are installing from a copy you've had knocking around, it may have become corrupt. Try all of this with your AV software disabled.
Regards
CTS2013
Message 18 of 29
VictorBDEngineer
Tried using Revo Uninstaller but with no success.
Publisher 2013 stops running when started with an exception (see attached snapshots). I have also attached the install logs in temp.zip.
Any other suggestions?
I am going to give up on this and wait for Publisher 2015 which is due end of this month. Hopefully I will have better luck with that.
In the mean time I might try Solidworks Composer.
Regards
Victor
Message 19 of 29
Well I have given Solidworks Composer a little try and it will do the job for me but not as well as Publisher. A little bit of a steep learning curve and some changes in my documentation procedures but I have to get the project out.
Because I cant get Publisher going I have unfortuneatly lost access to all my Publisher files which is a bit of a pain. Hopefully I will not have to use them in the near future. For my latest project I will go with Composer but for my next project I would like to go back to Publisher. Hopefully Publisher 2015 is a better product than 2013, 2013 R1 and works on my system.
regards
Victor
Message 20 of 29
Well I have downloaded and installed Publisher 2015 and surprise surprise it does not work. Selecting create new causes the program to exit with no error messages. I do not even get the chance to insert a model.
I can open an existing .ipb file and view it. If I then select 'New' the program once again crashes without any error messages. This is not very helpful.
I will continue using Solidworks Composer for future work and use Publisher 2015 to read my old .ipb files.
I am disappointed with this software.
Regards
Victor
