Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Performance issue
13 REPLIES 13
Message 1 of 14
bowen192
941 Views, 13 Replies
Performance issue
If I could make a suggestion...
In Options you have the ability to reduce the sharpness of the graphics to make manipulation easier.
I would really like an option to take the graphical level of detail right down to the minimum.  After all, I'm only bothered what it looks like when I finally decide to output an image/video/whatever.
13 REPLIES 13
Message 2 of 14
TimeraAutodesk
in reply to: bowen192
Hey there,
Have you used the Viewport Fidelity slider from the View tab of the ribbon? This slider reduces the visual fidelity while working to help increase performance on large assemblies - but it wont affect the quality of the model once published. Sounds like this is exactly what you're looking for.
Timera
Message 3 of 14
bowen192
in reply to: TimeraAutodesk
Thanks Timera,
I am aware of this option, but the level of detail is still quite high, even all the way to Rough.
On files with a large amount of components, the performance of Publisher is still unnaceptable, and I was thinking maybe reducing the level of detail even more would allow us to be able to maniuplate an object to the standard of Inventor.
Message 4 of 14
TimeraAutodesk
Hmm... right now the only other option would be during the Import/Insert process. For Inventor assemblies, you've got the option to control Faceting.
We are continuing to work to find solutions for performance with large assemblies, but in the meantime these 2 options are what we have to help with this workflow.
Timera
Message 5 of 14
bowen192
Thanks, Timera, I'd not even noticed this option before.
So if I import it this way, can I then generate the final image/video/vector in a higher quality?
Message 6 of 14
TimeraAutodesk
Vector will generate at the same quality regardless of what faceting setting you insert a model at. As far as video, images, etc. though the model will publish with the same visual/faceting settings as what you import it as. Once the model has been imported with a setting, it cannot be changed later down the road.
I understand it isn't an ideal workflow, but I hope that helps.
Timera
Message 7 of 14
bowen192
It does, cheers.
Message 8 of 14
How do you control the faceting on parts imported/inserted through Vault?
Christian
Message 9 of 14
bowen192
in reply to: cms_eurowater
This option does not exist.
Message 10 of 14
cms_eurowater
*facepalm*
Message 11 of 14
bowen192
If it's any consolation, Autodesk have set-up a very smart Facebook page for Publisher. Smiley Indifferent
Message 12 of 14
cms_eurowater
Thank you for letting me know. I expect the Autodesk crew to reply faster on a social media.
Not sure if it really is a consolation, though 😉
Message 13 of 14
cts2013
I remember seeing this box when I first starting using Publisher but haven't seen it in a very long time. Where did it go?
- - - > Publisher 2016 running on: - - -
Intel Core i7 3770k @ 3.5Ghz
Quadro K4000
16GB RAM
Intel SSD
Win10 64bit
Message 14 of 14
cts2013
"If it's any consolation, Autodesk have set-up a very smart Facebook page for Publisher."
And by Jove it makes large assemblies much easier to manage! Smiley Wink
Quadro K4000
16GB RAM
Intel SSD
Win10 64bit
