Inventor Publisher
bowen192
Message 1 of 14 (508 Views)
Performance issue
508 Views, 13 Replies
08-08-2012 01:56 AM
If I could make a suggestion...
In Options you have the ability to reduce the sharpness of the graphics to make manipulation easier.
I would really like an option to take the graphical level of detail right down to the minimum.  After all, I'm only bothered what it looks like when I finally decide to output an image/video/whatever.
Employee
TimeraAutodesk
Message 2 of 14 (504 Views)
Re: Performance issue
08-08-2012 08:54 AM in reply to: bowen192
Hey there,
Have you used the Viewport Fidelity slider from the View tab of the ribbon? This slider reduces the visual fidelity while working to help increase performance on large assemblies - but it wont affect the quality of the model once published. Sounds like this is exactly what you're looking for.
Timera
bowen192
Message 3 of 14 (501 Views)
08-08-2012 09:10 AM in reply to: TimeraAutodesk
Thanks Timera,
I am aware of this option, but the level of detail is still quite high, even all the way to Rough.
On files with a large amount of components, the performance of Publisher is still unnaceptable, and I was thinking maybe reducing the level of detail even more would allow us to be able to maniuplate an object to the standard of Inventor.
Employee
TimeraAutodesk
Message 4 of 14 (498 Views)
08-08-2012 09:53 AM in reply to: bowen192
Hmm... right now the only other option would be during the Import/Insert process. For Inventor assemblies, you've got the option to control Faceting.
We are continuing to work to find solutions for performance with large assemblies, but in the meantime these 2 options are what we have to help with this workflow.
Timera
bowen192
Message 5 of 14 (475 Views)
08-14-2012 03:03 AM in reply to: TimeraAutodesk
Thanks, Timera, I'd not even noticed this option before.
So if I import it this way, can I then generate the final image/video/vector in a higher quality?
Employee
TimeraAutodesk
Message 6 of 14 (471 Views)
08-14-2012 07:52 AM in reply to: bowen192
Vector will generate at the same quality regardless of what faceting setting you insert a model at. As far as video, images, etc. though the model will publish with the same visual/faceting settings as what you import it as. Once the model has been imported with a setting, it cannot be changed later down the road.
I understand it isn't an ideal workflow, but I hope that helps.
Timera
bowen192
Message 7 of 14 (467 Views)
08-14-2012 08:35 AM in reply to: TimeraAutodesk
It does, cheers.
Member
cms_eurowater
Message 8 of 14 (133 Views)
04-03-2014 05:23 AM in reply to: TimeraAutodesk
How do you control the faceting on parts imported/inserted through Vault?
Christian
bowen192
Message 9 of 14 (129 Views)
04-03-2014 05:50 AM in reply to: cms_eurowater
This option does not exist.
Member
cms_eurowater
Message 10 of 14 (124 Views)
04-03-2014 06:27 AM in reply to: bowen192
*facepalm*
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
