Inventor Publisher
Member
priit
Message 1 of 8 (1,010 Views)
Inventor publisher viewer for android
1010 Views, 7 Replies
12-08-2012 03:19 AM
Hello
I want to inquire wether Autodesk is still working on the Publisher viewer for android?
Because, right now, it isn't working!
Case in point:
I created an IPM of an assembly i need to show to my clients. The IPM file opens fine on an iPad2, but when trying to open on different android products, it only says "Exceeds device capacity".
Android devices tried on:
Samsung Galaxy Tab 7.7
HTC One X
Nexus 10
The last two i know for a fact, in terms of hardware and overall capabilities, far exceed the iPad2, regardless neither can open the IPM.
With regards
Priit
Employee
LeoWan
Message 2 of 8 (993 Views)
Re: Inventor publisher viewer for android
12-09-2012 06:24 PM in reply to: priit
would you mind sharing the ipm file? we can then do further inventigation on this.
Publisher QA
Member
priit
Message 3 of 8 (967 Views)
12-11-2012 12:40 AM in reply to: priit
Link for the file sent to you via PM
Employee
irene.chen
Message 4 of 8 (951 Views)
12-11-2012 11:41 PM in reply to: priit
Hi Priit,
Thanks for your shared file, we did some invenstigation for your file, this issue happens because there are much mesh data in the file, which is outside the capacity limitation.
The only workaround for you here is to seperate the file as smaller one with less mesh data.
Irene Chen
Inventor Publisher QA
Member
priit
Message 5 of 8 (941 Views)
12-12-2012 08:08 AM in reply to: irene.chen
Hello
That doesn't really explain how it works on an iPad2 though
Employee
irene.chen
Message 6 of 8 (867 Views)
12-25-2012 08:53 PM in reply to: priit
The Publisher Mobile viewer on Android and IOS are different because of the complex hardware and system environment.
Irene
Member
priit
Message 7 of 8 (838 Views)
01-02-2013 03:18 AM in reply to: irene.chen
There is no such thing as too complex.
When can Android users expect properly optimized Publisher Viewer thats on par with the iOS version? I don't feel like buying an extra tablet to run one app.
Employee
irene.chen
Message 8 of 8 (815 Views)
01-04-2013 11:30 PM in reply to: priit
The different performance on the same file is caused by the underlying platform (iOS/Android). Generally, iOs's performance is better than Android. and some of the android devices are not powerful as the iPad. The code of the Publisher viewer on the Android and the iOs is almost same, so we don't have a plan to optimize our code. Hope Google will optimize the Android platform, and let it become better.
Irene Chen
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
