Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Inventor Publisher Service Pack 1 is now live
14 REPLIES 14
Message 1 of 15
rajkumar.ilanchelian
1234 Views, 14 Replies
Install Inventor Publisher SP1 from here.
-Raj (Autodesk)
14 REPLIES 14
Message 2 of 15
Finally! Hope this will tackle the 'unknown error' and many other problems.
Message 3 of 15
And it still doesn't show up half the textures for me.
I'm seriously going to have to start looking for an alternative now.
Message 4 of 15
TechNico_nl
in reply to: bowen192
I downloaded and installed SP1. I can't see the changes, maybe in the background. Errors still there, something in my file is corrupt I think. For 4th time I'm going to ask Autodesk to repair it. Getting tired and frustrated of Publisher Smiley Sad
Message 5 of 15
FrankZhou
in reply to: TechNico_nl
Can you give us a brief description of your problem? Or can you just mail me(frank.zhou@autodesk.com) and describe your file corruption issue in the mail, we will try our best to fix the file corruption for you.
Message 6 of 15
TechNico_nl
in reply to: FrankZhou
My file problems are known by Autodesk for weeks now. I've contact with the development team 5-10 times a week. But they can't give a solution and the SP1 didn't solve it. They just have to 'repair' my file and I can go on. Most of the time the problem occurs after updating the source files and then re-open the updated *.ipb file (after saving).
Message 7 of 15
bowen192
It's the same old issue that I've had for months.
The textures disappear and default to grey.  I wouldn't mind so much if it wasn't for two main reasons;
1/  The model is created in Autodesk Inventor
2 / The problem never occured in Publisher 2011.
I've owned 2012 for about three or four months now, and I haven't used it once.
Tags (3)
Message 8 of 15
mark.lambert
Are you possibly using custom Inventor colors or materials?  Those materials will default to grey in Publisher.
Mark
Message 9 of 15
bowen192
in reply to: mark.lambert
Mark
I am using the standard choice of materials that come packaged with Inventor.
For example; As Material > Metal-Steel (Rusted)
Message 10 of 15
mark.lambert
Ok.  Thanks.
Can you possibly share your file so we can see what's happening?
Mark
Message 11 of 15
I tried using the Metal - Steel (Rusted) on a simple Inventor part and it came in correctly in Publisher 2012. There should be more to the file that you are using I believe. Would it be possible to share a small Inventor file that you are seeing this problem in 2012?
Please email me directly rajkumar.ilanchelian@autodesk.com and I can send you a secure ftp site to upload the dataset.
-Raj (Autodesk)
Message 12 of 15
Thanks for sending in the dataset. Your model currently has a texture image for color and Publisher currently does not support this workflow.
We bring in material color and also a color override but not color override from a texture image.
I will take this issue back to our development team and see if there are any workarounds possible.
-Raj (Autodesk)
Message 13 of 15
I just installed it and it killed my Office 2010 COM Add-in for Publisher and everytime I try to restart it, it pulls a run-time error and will not load.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 14 of 15
Tianq
in reply to: mflayler2
Could you please try this workaround in the link http://forums.autodesk.com/t5/Autodesk-Inventor-Publisher/Publisher-Word-add-in-does-not-work-after-...
Dave, Publisher Developer.
Dave (Qing) Tian
Sr. Software Engineer
Message 15 of 15
mflayler2
in reply to: Tianq
That worked beatfifully, thank you!
