Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Installation Inventor Publisher 2011: error 1638
5 REPLIES 5
aesop
1634 Views, 5 Replies
I tried to install the English version of Inventor Publisher a few days ago, which got me an error 1638. And now I try to install Inventor Publisher 2011 in German -> same error.
What to do now?
I Already tried to uninstall, clean up registry, delete all Program Files and Documents and Settings directories created by Inventor Publisher setup.
Here is the log file:
Spoiler
2010/9/30:10:37:51    h.ungul-inst    M4300-1    === Setup started on M4300-1 by h.ungul-inst ===
2010/9/30:10:37:57    h.ungul-inst    M4300-1    === Setup ended ===
2010/9/30:10:37:55    h.ungul-inst    M4300-1    === Setup started on M4300-1 by h.ungul-inst ===
2010/9/30:10:44:06    h.ungul-inst    M4300-1    Install    .NET Framework Runtime 3.5 SP1    Succeeded
2010/9/30:10:44:26    h.ungul-inst    M4300-1    Install    DirectX 9.0 Runtime    Succeeded
2010/9/30:10:47:50    h.ungul-inst    M4300-1    Install    Autodesk Inventor Publisher 2011    Succeeded
2010/9/30:10:47:54    h.ungul-inst    M4300-1    Install    Autodesk Inventor Publisher 2011 Language Pack    Failed    Installation aborted, Result=1638
2010/9/30:10:49:13    h.ungul-inst    M4300-1    Rollback    Autodesk Inventor Publisher 2011    Succeeded
2010/9/30:10:49:14    h.ungul-inst    M4300-1    Rollback    DirectX 9.0 Runtime    Failed    Failure is ignored, Result=1619
2010/9/30:10:49:14    h.ungul-inst    M4300-1    Rollback    .NET Framework Runtime 3.5 SP1    Failed    Failure is ignored, Result=1619
2010/9/30:10:51:55    h.ungul-inst    M4300-1    Install    DirectX 9.0 Runtime    Succeeded
2010/9/30:10:53:26    h.ungul-inst    M4300-1    Install    Autodesk Inventor Publisher 2011    Succeeded
2010/9/30:10:53:29    h.ungul-inst    M4300-1    Install    Autodesk Inventor Publisher 2011 Language Pack    Failed    Installation aborted, Result=1638
2010/9/30:10:54:34    h.ungul-inst    M4300-1    Rollback    Autodesk Inventor Publisher 2011    Succeeded
2010/9/30:10:54:34    h.ungul-inst    M4300-1    Rollback    DirectX 9.0 Runtime    Failed    Failure is ignored, Result=1619
2010/9/30:10:55:03    h.ungul-inst    M4300-1    === Setup ended ===
5 REPLIES 5
aesop
in reply to: aesop
I forgot to mention:
Windows XP SP3, 32bit.
Smiley Wink
aesop
in reply to: aesop
My colleague fixed the problem:
Uninstall Java and then reinstall Inventor Publisher -> no more errors!  🙂
Jon.Balgley
in reply to: aesop
I'm glad *you* found the solution -- not sure how long it would have taken *us* to figure that out!
Jon Balgley
emacleod
in reply to: aesop
Tried this and I am still not able to install publisher 2011.
Jon.Balgley
in reply to: emacleod
Can you please send us the following files, if they exist?
%temp%\Autodesk Inventor Publisher 2011 R1.log
%temp%\Autodesk Inventor Publisher 2011 R1 Beta.log
%temp%\Autodesk Inventor Publisher 2011.log
"%temp%" varies from machine to machine.  You can start a "cmd" window, and type "cd %temp%" to find out where it is on your machine.
Jon Balgley
