Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Insert From Vault - Unhandled exception
8 REPLIES 8
Message 1 of 9
jweiss1313
1875 Views, 8 Replies
I have a user who is trying to insert an Inventor 2012 file into Inventor Publisher 2012..
Here is his workflow:
Opened Publisher 2012
Clicked Create New File
Went to Vautl tab in ribbon panel
Clicked on the insert button
Drilled down into Vault Product libraries folder and clicked on Saturn folder and got the error shown in the attached screen capture.
The user hit the continue button and nothing happens.  The user then closed the application and re-opened and gets the same result.  He does not get this error on all folders, but he does on some..
I just tried the same workflow on my workstation and I do not get this error.
Please help ASAP because my user cannot get his work done.
Thanks!
John C Weiss Jr.
CAD Manager
Follett LLC.
8 REPLIES 8
Message 2 of 9
jweiss1313
in reply to: jweiss1313
I want to keep this problem relevant because this problem also exists in Publisher 2013 but instead of getting an error message, Publisher crashes.  See Autodesk case 07709148.
Please help!
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 3 of 9
LeoWan
Thank you for reporting this issue. I have filed a issue in our internal track system.
By the information of the screenshot, I guess there might be a file which has no file extension in the 'problem' folder.
If yes, please try this workaround :
rename the no extension file to has a extension or remove this no extension file.
Publisher QA
Message 4 of 9
jweiss1313
in reply to: LeoWan
That is not the issue at all.  This is a Vault folder filled with 1811 Inventor files.  Inventor Publisher will not display the contents of certain Vault folders and we get this error in Pub2012.  In Pub2013, we do not even get an error, the application crashes. These folders are children folder in Vault with ACL's defined by the parent folder, so we should have the same permissions in every child folder.  The problem is that we don't, only in Publisher.  We cannot access certain folders in Vault because of this error and we are unable to get our work done!
See tech support case #07709148 for more details
I'm attaching a copy of the error details.
Thanks for your help with this issue.
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 5 of 9
jweiss1313
I just received a new dll file from the Autodesk Publisher development team and it fixed the problem.  Thanks to all at Autodesk who helped fix this problem for us!
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 6 of 9
hgulen33
Hi friends. In recent days I've installed Autodesk Vault 2018 Pro Client. When I launched Vault an error throwed that shows up below in the picture. I can't understand that error. Thank you for your helps.
Message 7 of 9
jweiss1313
in reply to: hgulen33
Are you trying to insert a file into Inventor Publisher?  This thread is for an Inventor Publisher error.  Inventor Publisher was discontinued last year and is not compatible with Vault 2018.
John C Weiss Jr.
CAD Manager
Follett LLC.
Message 8 of 9
hgulen33
I apologize for wrong thread. This error related Vault 2018 Pro Client not related Inventor Publisher. Then Vault 2018 Client launched that error occurs
Message 9 of 9
hgulen33
My problem is not related the Inventor Publisher. I'm so sorry for wrong threat. It was careless of me. This error only is showing when Vault Client 2018 Pro App lanunched. Thank you for your understanding.
