How is it possible to import a Inventor IPN file with animation in Publisher?
Solved by Jon.Balgley. Go to Solution.
IPN's can be exported to DWF, and Publisher reads DWFs. In order to bring in any animations, you'll probably want to use the Options button which is available in the "open" dialog after you have selected the DWF file. However, I am not sure whether you'll get everything you want from the IPN to the DWF to Publisher ... Publisher was not intended to be a direct replacement for IPN's, although obviously there is a lot of overlap. If you have specific problems, post them here.
